Toshiba c660d PSC20E-00U001Y4 bios need
  • grec
    • Mar 2013
    • 21
    • BiH
    can anyone post bios dump of
    toshiba satellite
    model: c660d-1E5
    part no. PSC20E-00U001Y4
    motherboard: PWWBE LA-6849P
    Rev: 2.0
    2010-12-29
  • Saidogoid
    • Jul 2016
    • 5
    • Portugal
    Re: Toshiba c660d PSC20E-00U001Y4 bios need
    Anyone? i need it too.
    Plz
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      try this but make backup
      Im Back... sort of...
      • ZARD0Z
        • Jul 2017
        • France
        Thank You!
        As many people, I froze this laptop by updating BIOS to v1.6 ***PROVIDED*** by Toshiba on their site for this Satellite C660D-19X !!!
        • 22VDFR
          • Sep 2017
          • 9
          • PORTUGAL
          https://www.badcaps.net/forum/attach...0&d=1491473070
          this works.. thanks
          • Wahid Gul
            • Jun 2017
            • 5
            • Afganistan
            Thanks bro it dose a work 100% i check it it work
            toshiba c660d has password i program it then removed password
            thanks again
            • teknikpc
              technical
              • Dec 2016
              • 61
              • Türkiye
              thanks ala_borbe
              • egelaptop
                • Jun 2015
                • 121
                • türkiye
                hello friends bios in the link did not boot does not boot if you have any other file can share
                • peste
                  • Dec 2016
                  • 12230
                  • ROMANIA
                  post # 3 did you try it?
                  • egelaptop
                    • Jun 2015
                    • 121
                    • türkiye
                    yes I tried the image is coming but it does not continue cursor flashes continuously
                    • peste
                      • Dec 2016
                      • 12230
                      • ROMANIA
                      Post your bios.
                      • boskorp
                        • Sep 2019
                        • 8
                        • Bulgaria
                        Extracted the ROM/BIN files (w/ 7Zip) from the original BIOS from Toshiba. They are the same (hash check) with those from post #3. For some reason the original Phoenix flash tool updated the discrete graphics BIOS version on an UMA board. Manually flashed it using RT809F programmer. Working fine.
                        • shomi75
                          • Mar 2011
                          • 7
                          • Serbia
                          uma works for me
                          • krist
                            • Sep 2020
                            • 3
                            • France
                            Can someone post the method to reinstall the BIOS on Toshiba Satellite C660D after a failed BIOS update? What do I have to do with the rom file in post#3?
                            Thanks in advance
                            • Mazorca
                              • Jan 2017
                              • 463
                              Thanks in advance
                              You need a programmer such as TL866ll and desoldering skills. First, find and identify your own Bios chip, desolder it (some people can use a clip, I cant) make a backup with programmer, write the bin file given here, and solder it back again, test it. If it doesn't work, try another bin, or the failure might be elsewhere, reinstall backup. Check for Bios voltage going in too, before doing all this.
                              • krist
                                • Sep 2020
                                • 3
                                • France
                                Thanks for the answer. Is there a way to boot on USB stick and force failed BIOS replacement? This is for Toshiba Satellite C660D
                                • Mazorca
                                  • Jan 2017
                                  • 463
                                  I personally do not know how, try to google it. Most video problems on older computers are related to video card overheating, try the low heat method, 2 min at 130 degrees C. DO NOT use a heat gun, temps are waaaay to high, and do not "cook" it inside oven, youtube has lots of videos doing that.
                                  • krist
                                    • Sep 2020
                                    • 3
                                    • France
                                    The problem comes from a failed bios update. This is why I want to know if this is possible to reinstall bios from a USB stick.
                                    • vtfe
                                      • Sep 2017
                                      • 35
                                      • france
                                      As others here, I flashed my Toshiba with wrong BIOS version. C660D-14C. I was stupid enough to flash with a BIOS from the Toshiba website for a slightly different model (C660D-14V vs. 14C). Restarted to a blank screen
                                      Reflashed with the UMA BIOS version from Ala Borbe. Worked like a charm! Thank you, bro
                                      @ Krist: I don't know if you can flash with a USB stick. I reflashed with a CH341a programmer. Google it or PM me if you need more info.
                                      • kayitsiz
                                        • May 2017
                                        • 18
                                        • istanbul
                                        Thanks ala_borbe, it work.
                                          Toshiba Satellite C660D-1E2 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite C660D-1E2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660D-1E2 boardview and C660D-1E2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-06-2024, 07:29 AM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Wahaz
                                          by Wahaz
                                          10-30-2023, 08:42 PM
