Lenovo ThinkPad Edge E531 BIOS
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Hi Friends,
    Anyone have Lenovo Thinkpad Edge E531 VILE2 NM-A044 Bios Dump. I need both Ec & Main.
    Thanks in advance
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo ThinkPad Edge E531 BIOS
    If needed i can post my defective backup
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Laptop keeps on restarting with no display but if i remove ram then it does'nt restart. Seems like bios issue.
      I have attached my backup(likely defective ). Can anyone fix this??
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        Try with this
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I'll try and revert back with result ridamoth159 sir. Thanks for uploading
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            Hi Friends,
            Thanks in advance
            try this...
            your bios version : HEET42WW
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Thanks Rioreno. Your dump worked but sorry to say Ridamouth's dump didnt worked
              • mopriessnig
                • Jul 2017
                • Österreich
                Hi, can you please post how you replaced the bios (chip) dump? Thanks in advance, BR, Martin
                BIOS update failed, got 2 new BIOS chips 32 and 64MB and would like to know how to change?
                • alaasniper3
                  • Jun 2014
                  • 13
                  • jordan
                  not working
                  • Pascal Komlassan
                    • Jan 2017
                    • 809
                    • TOGO
                    Originally posted by ridamouh159
                    try with this
                    thanks bro its work for my motherboard
                    • Simon16
                      • Sep 2017
                      • 102
                      • España
                      Originally posted by rioreno
                      try this...
                      HEET44WW_PCH.bin should I write it in CFEON EN25QH64, HEET44WW_Main.bin should I write it in CFEON EN25QH32 but where should I write it and how HEET44WW_EC.bin?
                      Can you help me?
                      Regards
                      • lesterbrazal
                        • Aug 2011
                        • 38
                        Try with this
                        thanks its working
                        • Umdaman
                          How do you program these Dump files into the Bios? Does the bios chip need to be removed? Or can these files be flashed within windows with flasher software?
                          Thanks.
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            Why would you want to flash a dump if your laptop boots to Windows.
                            But answering your question - no, usually it doesn't have to be removed but you still need an SPI programmer attached to the bios chip. Newer laptops can't be programmed with dump files within an operating system.
                            • Umdaman
                              Because I have a E531 that someone put a stupid supervisor password on the bios. So now can only make minor changes to the bios settings. I found a flash that would clear out the supervisor password. But sounds like I will need to have a programmer attached which I don't have.
                              • RethoricalCheese
                                • Mar 2013
                                • 1519
                                • Estonia
                                Then buy one. They are cheap. Ch341A only a couple euros and minipro is 10-15 euros I think.
                                • Mhf
                                  • Apr 2018
                                  • 5
                                  • Iran
                                  try this...
                                  thank brother test ok
                                  • baiceanu_stefan
                                    • Feb 2015
                                    • 40
                                    try this...
                                    working. many thanks
                                    • KRAMEZZ
                                      • Jan 2021
                                      • FRANCE
                                      Sorry to be noob, but wich file go in wich IC ? I have CH341A prog.
                                      Initial problem power on/off loop, no screen, fn key light up when power on.
                                      Not completely dead because it respond to FN+R bios recovery mode, but unable to find the way it work, tested wincrisis for phoenix bios but not work.
                                      • TTR
                                        • Apr 2020
                                        • 24
                                        • Poland
                                        try this...
                                        I can confirm that this dump is working. I didn't need to flash ec firmware though.
                                        Thank you
                                        • lucaszmn
                                          by lucaszmn
                                          Problem:
                                          Initial Findings:
                                          • I concluded that the
                                          08-12-2025, 03:01 PM
                                        • to5it0
                                          by to5it0
                                          Today, 01:35 AM
                                        • 1g0r
                                          Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                          by 1g0r
                                          First, the data in brief:
                                          Manufacturer: Lenovo
                                          Model: ThinkPad L15 G3 21C3-0016GE
                                          motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                          IC Bios 1: MX77L25650F
                                          IC Bios 2​: MX25L25673G
                                          EC Chip: NPCX997KAABX
                                          So far I've been a silent reader, but now I need your help
                                          I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                          I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                          The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                          01-18-2025, 02:39 AM
                                        • MaxonDomkrat
                                          Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                                          by MaxonDomkrat
                                          Hi everyone.
                                          I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                                          07-30-2025, 01:27 PM
                                        • akwky
                                          by akwky
                                          Hi!
                                          04-14-2025, 01:56 PM
