ASUS every boot appears bios screen
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Every start, appears a bios screen.
    Asus rog G75VX, I resolved a power issue: replaced a mosfet near the power pin, drived by the ACDRV signal from
    TI BQ24735.
    During a motherboard test phase, it appears the bios screen in a few seconds.
    After reassembly the laptop:
    - first start, after a lot of time (20 sec), appears bios screen but boot override with linux pen don't work.
    - second start, after a lot of time...., bios screen, no device detected.
    Using this setting, the laptop starts with the usb pen:
    disable Secure Boot, Save and reboot, Enable CSM , after restart it boots with linux pen, BUT.
    what is the cause of this delay ? I have noticed this is a common issue in Asus laptops and in some HP for example after the use
    of a bios dump.
    It could be a problem on ec, or ? (last week I have solved a similar issue on an asus, the culprit was a resistence on RTC RESET signal, but this is not the same situation)
    I have a post card, but on asus notebook works only with jdebug port ; there is another procedure to see all bios post code ?
  • throwaway327
    by throwaway327
    Model No: RC72LA
    Serial No: SBNVKD001014459
    06-18-2025, 05:52 PM
  • razor_amd
    by razor_amd
    12-15-2020, 07:07 PM
  • Technodoc
    ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
    by Technodoc
    Asus laptop G614JZ-N3012W Rog Strix with i7
    Mainboard G634J-PMV-VGT
    6050A3441302-MB-A01
    2023-02-10
    Power button works okay....power light goes on
    Red "bottom" leds go on
    Charging led works
    Fans do not spin, capslock key does nothing, screen stays black
    I would like to program the bios again, to rule out a corrupted bios.
    However I run into a size error
    The bios chip is a Winbond 25R256JVEN
    Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
    02-24-2025, 04:46 AM
  • futadmytro
    Asus g713qm-es94 stuck on boot bios problem
    by futadmytro
    sn^M4NRKD02753616E
    MB- g533-6050a3250201-MB-A03
    Stuck on boot after ROG logo, did not enter to bios
    In flash bios , laprop boot but have video issue
    orig bios...
    06-25-2025, 08:07 AM
  • oragano
    ASUS ex-b250-V7 motherboard bios corrupted - by me
    by oragano
    hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
    So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
    i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
    10-17-2024, 02:53 AM
