Request ZBook 15 G3 Bios Dump
  • momamolo
    • Jul 2025
    • 11
    • France
    #181
    Hi everyone! I have the board view for my motherboard, but I’m not sure where to solder each pin of the BIOS chip since the original pads are damaged. Could anyone guide me on which alternative points to use for each pin? Any advice would be greatly appreciated
    Zbook 15 G3 , board APW50 LA-C381P
    • khelane
      • Apr 2015
      • 168
      • xxxx
      #182
      Hello
      can someone fix this BIOS for me?
      APW50 LA-C381P REV 1A
      the laptop start with no display and all voltages are present.
      Two bios tested but no display
        • 20966
        Originally posted by khelane
        Hello
        post the laptop serial number...
        • khelane
          • Apr 2015
          • 168
          • xxxx
          #184
          CMIT :2015AJ2225
          SN: CND64258N6
          A/S: 1588-3003
          PROD ID: M9R63AV
          HP ZBOOK G3
          LA-C381P REV:1A
          • khelane
            • Apr 2015
            • 168
            • xxxx
            #185
            CMIT :2015AJ2225
            SN: CND64258N6
            A/S: 1588-3003
            PROD ID: M9R63AV
            HP ZBOOK G3
            LA-C381P REV:1A
            Please help me
            • shiyab
              • Sep 2023
              • 1482
              • india
              #186
              Please help me
              hi try
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                by haitham sharabati
                Hello engineers 😀,
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                💀 Problem:😅
                08-07-2025, 04:54 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • loopster
                Need help cleaning ME region on Zbook 17 G1 bios dump
                by loopster
                Hello guys,
                could I please get some help cleaning the ME region of the attached Zbook 17 G1 bios dump (CH341a, neoprogrammer, chip-desoldered, dumped twice, identical checksum)?
                Symptoms, delayed BIOS post (ca. 45 secs.) keyboard not working, touchpad not working, booting linux live, console says "Management engine not configured".
                I tried following the ME firmware cleaning guide, but whatever Flash Image Tool version I try, I get the same error:
                Error 10: Failed to open with processed commands.
                Unable to open file: C:\Users\Elitebook...
                06-16-2024, 09:57 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
