UEFI Help: How edit BIN Bios File? SONY SVF14 DA0HK8MB6E0
  • bora_vr6
    • 12
    • Mexico
    Present post if for kindly ask for your help and guidance about how edit/modify the BIOS Dump from a Sony Vaio Fit 14E Model: SVF142c29L MoBo: DA0HK8MB6E0
    I used to have a damaged Mother Board, Bios upgrade process kill the machine, however now is working, based on a Dump Bios file founded for this MoBo; the BIOS Winbond Chip has been re-writed and now MoBo boots ok.
    Now, the question and support items are:
    a).- How edit the Model? without damage the BIOS file
    b).- And most important; how edit the UEFI settings? (if required).
    1.- I found the model SVF14215CLB and I would like to replace for the specific model of the equipment on the Dump File , the question is how can be possible the BIOS File edit without damage the rest of the file structure of the BIN?
    2.- The UEFI is a new thing for me, and I don't know if this one should be changed for re-install Win8 or UPG to Win10, without causing that UEFI key cause conflict with another Register on the Microsoft files (in case some other computer on the Web uses this UEFI where dump is globally shared).
    Kind Regards.
    Here's the CAP used and the one that works ok for this BIOS MoBo.
  • lenovx
    • Nov 2016
    • 12
    • maroc
    Re: UEFI Help: How edit BIN Bios File? SONY SVF14 DA0HK8MB6E0
    its working......... thanks bro
    • m1ch43lzm
      by m1ch43lzm
      Hi everyone
      09-06-2025, 05:47 PM
    • ahmedtou
      HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
      by ahmedtou
      help me please
      I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
      When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
      I will share all the details with you, including the disc information.
      Code:
      HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
      Current Profile: BD-R
      Disc Information:
      Status: Empty
      State of Last Session: Empty
      Erasable: No
      Free Sectors: 12,219,392
      Free Space: 25,025,314,816 bytes
      Free Time: 2715:27:17 (MM:SS:FF)
      Next
      08-27-2025, 08:49 AM
    • mariukonie
      SONY VAIO PCG-711911M VPCEH2H1E advice about updating BIOS to UEFI needed please!
      by mariukonie
      Hi. I can't upgrade to win11 I think it's because my BIOS is without Secure Boot function. The BIOS version is R0180Z9. Can you please advise if it is possible to upgrade BIOS to UEFI for this laptop. Many thanks....
      05-04-2025, 03:18 PM
    • Forest79
      by Forest79
      07-23-2023, 07:39 AM
    • ioosis
      bordview file needed for sony flip DA0FI2MB6D0 version e sony SVF14N13cxb
      by ioosis
      hi there
      i need( bordview) file needed for sony flip DA0FI2MB6D0 rev. e sony flip 14 model SVF14N13cxb
      i can not get free anywhere any help would be apperciated
      03-08-2022, 02:18 AM
