HP 14-ac102tx
  • smali
    • Sep 2014
    • 287
    • Pakistan
    HP 14-ac102tx
    @rioreno @ala_borbe
    Could you please fix this dump.
    thanks
    Hp 14-ac102tx board ID.. 6050A2730801-MB-A01
    NOTE...i download from original hp web site and decrypt as per COPY option but that file not working.
    backup dump is here
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: HP 14-ac102tx
    Try this.
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Re: HP 14-ac102tx
      Thanks Imran... did not work
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        Re: HP 14-ac102tx
        Originally posted by smali
        @rioreno @ala_borbe
        thanks
        backup dump is here
        try this
        • u.notebook
          • Jun 2019
          • Argentina
          Re: HP 14-ac102tx
          this? I hope it works...
          • daniel0314
            • Apr 2017
            • 14
            • SOMALIA
            Re: HP 14 6050a2730801-mb-a01
            helloo
            i need the ec dump plisss
            ite8987e
            • jihadmulla
              • Dec 2020
              • bangladesh
              Re: HP 14-ac102tx
              hello i need a hp bios 6050a2730801-mb-a01
              • peste
                • 12944
                • ROMANIA
                Re: HP 14-ac102tx
                post the full name and model of the laptop and the original bios, the bios backup.
                • djharold
                  • Aug 2015
                  • 241
                  • COLOMBIA
                  Re: HP 14-ac102tx
                  Originally posted by imranromi
                  Try this.
                  thankyou I try this may be work
                  • Abir Emdad
                    • Feb 2018
                    • 12
                    • Bangladesh
                    6050a2730801-mb-a01 100% ok tested file....
                    • pretendjury84
                      Decrypt Keychain file
                      by pretendjury84
                      Sorry if this is posted in the wrong section.
                      I need to decrypt a .keychain file. The methods listed on github (https://github.com/n0fate/chainbreaker) unfortunately dont seem to work. Im getting stuck on the first bit,
                      1. Navigate to the directory containing the file setup.py
                      2. Enter the command (from terminal): $ python setup.py bdist_wheel -d dist. This creates a wheel file (extension: .whl) in the /dist folder.
                      qashifmasud@Qashifs-MacBook-Pro chainbreaker-master % python setup.py bdist_wheel -d dist
                      zsh: command not found: python
                      qashifmasud@Qashifs-MacBook-Pro...
                      10-12-2024, 02:31 AM
                    • dchandler@lifetimeservice
                      BIOS unlock or decrypt password for Asus S533F serial L6N0CV190141266
                      by dchandler@lifetimeservice
                      Could someone help me out either decrypting the administrator password, or removing entirely? Password was forgotten by user.
                      Current BIOS firmware version is X521FA-305
                      Thank you!...
                      07-02-2025, 11:32 AM
                    • dannyholmes
                      HP EliteBook 725 G4 bios password DECRYPT
                      by dannyholmes
                      Hello, i bought many used EliteBooks 725 G4 and they are with bios password. They are all from one company so the passwords should be same.
                      Is someone able to decrypt the password from bios dump so i can try the password on other ones? Thanks!...
                      11-01-2022, 05:56 PM
                    • haopcxg
                      HP EliteBook 865 G9 - BIOS issue decrypt
                      by haopcxg
                      My HP EliteBook 865 G9 notebook was accidentally encrypted and could not enter the BIOS. It is relatively new. I extracted the data of the front and back memory of the motherboard: 6050A3334301-MB-AX1. I hope someone can help me....
                      01-17-2023, 09:29 PM
                    • Mazorca
                      HP Spectre XT Touchsmart 15-4011nr LA-8551P decrypt update
                      by Mazorca
                      I am having trouble decrypting the bios executable bin. I managed to get the bin but it is too big and nowhere looks like a bios. There are no identifing labels on the laptop bottom, I am taking my guess from the Bios dump and model on the touchscreen. Inside original bios are: C2M73UA#ABA and BID 01886.F12. Motherboard is labeled as LA-8551P and 700814-501. Symptoms are no video output, lighted keyboard keys (has backlight), keys beep when pressed, esc key does not, battery charging light is orange for a few seconds, turns white later. Mobo has onboard RAM chips, and uses DDR3L single RAM...
                      04-22-2021, 02:06 PM
