Dell inspiron 1564 bios needed
Channel: BIOS Requests ONLY!
by urad29Hi all,
I have a Dell Inspiron 15 3511 (Service tag: FY3C9T3) which is not booting past the Dell logo and I cannot enter the BIOS by pressing F2.
I therefore believe that the BIOS is corrupted.
I have spent some time trying to figure it all out as I have managed to reprogram BIOS's in the past.
The motherboard has two chips, one is a 25Q64JVSIQ and the other is a 25Q128JVSQ.
Firstly, how do I know which one is the BIOS, or are they both BIOS (have only worked on single BIOS boards).
Secondly, I cannot seem to get a bin file or the like from the BIOS exe...-
by jacospamaDell inspiron 15 3520 Bios needed
Reg Model- p112f
REg type- p112f00f
Services tag- BLW01Z3...-
by sahamipoorhi...
i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
i updated to latest version and try other version but not working!
service tag: HCQ3JW2
i need your kind....-
by zlr8rlooking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Dell Inspiron 17 (7786) Laptop
Service Tag: 5J0NHT2
Bios: 1.9.0
MOBO: RO 15 17 WHL 2GB MB / 18706-2
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...-
- Loading...
