Acer 7736zg bios wph to bin?
  • mnl
    • Oct 2013
    • 4
    • Greece
    I need the bin file to flash with CH341A
    The bios file from acer is wph:
    http://global-download.acer.com/GDFi...CER&SC=EMEA_27
    How to convert to bin?
    Thanks for any help!
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Acer 7736zg bios wph to bin?
    backup your old bios
    if you flash this from acer web, you will loose model, serial, and guid information in bios
    if you want me to fix it, post your backup here
    Im Back... sort of...
    • mnl
      • Oct 2013
      • 4
      • Greece
      Hi ala_borbe!
      The original bios chip had a crack on it possibly by a hit so i order a new MX- 12G 25L1605DM2I to reprogram it. Unfortunately i do not have the old one .Also i flash it with your file and still the same behavior .
      BTW thank you very much for your help!
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        it does not matter if it look damaged, put it in and try to read
        if you read data, its very much alive
        anyway, it might not be a bios problem at all, lots of other problems may give same or similar symptoms
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
        • to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
          by to5it0
          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
          I have opened the laptop and identified the main BIOS chip...
          10-24-2025, 01:35 AM
        • abhorsen
          Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
          by abhorsen
          Hey guys,
          Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
          Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
          Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
          07-06-2023, 10:22 AM
        • survivalbloke
          If I flash this bios file, will it just work, or does it need the ME cleaning?
          by survivalbloke
          I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
          ENVY X360
          15-ew0013dx
          SN: CND2261KS3
          Prod: 698V0UA
          Board: LA-M021P Rev 1A
          Chip# Winbond 25R128JVSN​
          Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...
          10-09-2024, 08:40 AM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
