Gateway NV53 (MS2285) bios dump
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Hi everyone I need this working bios dump file for this model Gateway NV53 (MS2285) I have attached the image of board id please help i need the file very urgent please
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: Gateway NV53 (MS2285)
    I have the same model laptop turns on but no display and led is present all voltage is present but there is no display I remember before when turn on this gateway laptop i need to press the power button for 5 seconds before turn on. Can someone share a working bios dump file for this model please share
    • String2016
      • Nov 2015
      • 2242
      • philippines
      anyone please can share working bios dump file for this model please
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        anyone can share a good working bios for this model I have the same model and board id I need this file also urgent please
        • String2016
          • Nov 2015
          • 2242
          • philippines
          anyone please help share the working bios for this model please
          • on/off
            • Oct 2016
            • 333
            • Indonesia
            try this
            • String2016
              • Nov 2015
              • 2242
              • philippines
              thanks ill tried your bios still the same issue laptop turns on fan spiining for 10 seconds then stop but power led light still presents and when I pressed power button for 10 seconds it turns on with display and then when i turn on again still the same issue fan spiining then pwer led presents but there is no display. I have attached the original bios file can someone please help me fix this problem. thanks in advance
              • String2016
                • Nov 2015
                • 2242
                • philippines
                update:after letting turns on without display for 5mins then push power button for ten seconds laptop turns on back to normal but after shutdown cannot turn on again you need to wait 5mins and press power button 10 seconds to turn on back normal can anyone help me please
                • String2016
                  • Nov 2015
                  • 2242
                  • philippines
                  anyone please help
                  • String2016
                    • Nov 2015
                    • 2242
                    • philippines
                    update i reflow the amd chip now the laptop cannot turn on totally dead please help fix this problem please
                    • amirarbabi
                      • Feb 2019
                      • 37
                      • usa
                      Re: Gateway NV53 (MS2285) bios dump
                      Tnks for bios
                      • rmosh77
                        • 4
                        • Jordan
                        thank you
                        • Ahari
                          by Ahari
                          I...
                          08-13-2025, 06:12 AM
                        • mkdj
                          by mkdj
                          Dear all,
                          10-19-2025, 04:41 AM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • haitham sharabati
                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                          by haitham sharabati
                          Hello engineers 😀,
                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                          🔧 Device Info:
                          - Model: HP 15-da2007ne
                          - Product Number: 8XF55EA#ABV
                          - Serial Number: CND0338P0D
                          - CPU: Intel Celeron N4000
                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                          💀 Problem:😅
                          - Device shows “Administrator Password”...
                          08-07-2025, 04:54 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
