urggent plz Dell Latitude E7470 Bios Password
  • volinakis
    • Jan 2021
    • 2876
    • N/A
    #161
    Re: urggent plz Dell Latitude E7470 Bios Password
    Originally posted by Doryss911
    Can anyone help me with a password reset for
    8K1SJC2-6FF1 ?
    thank you
    KM4czHRetWKBp3IE
    or
    2yDcQ9FdUPUraMxz
    ctrl+Enter+Enter
    • gotowiec27
      • Aug 2022
      • 14
      • Poland
      #162
      Could someone please help me with removing the admin password from this dump file? The BIOS image got corrupted and I cannot restore it from new image as it requires me to provide admin password and does not show the suffix.
      The service tag is HKDXR72
      Thanks in advance!
      • CammyTier1
        Tier 1 Assets
        • May 2022
        • 43
        Thanks in advance!
        Try
        B0tXFVcWZ0mpGWci
        or
        jG0Eq59kkjEG6QW2
        Press ctrl+Enter+Enter
        • gotowiec27
          • Aug 2022
          • 14
          • Poland
          #164
          Originally posted by CammyTier1
          Try
          B0tXFVcWZ0mpGWci
          or
          jG0Eq59kkjEG6QW2
          Hi, unfortunately neither of those two codes worked
          • OntarioTL
            • Feb 2022
            • 59
            Now before you send me links to the password generator as I have tried both on https://www.biosbug.com/dell/ and https://beta.bios-pw.org/ as they both spit out the same Result CODE to enter in order to override the password, it does not work with this unit whether it is just hitting enter or CTRL and Enter. Still says wrong password entered.
            I did try to flash with other E7470 clean ME files I found on the forums here, but while some got passed POST, it still has the password intact to override.
            I'm curious, is the password even on the BIOS chip to begin with? If so could someone work their magic to get rid of it?
            The system number is BT97VD2-6FF1. I even tried a different last 4 digit code from the biosbug website to generate a different key and no luck.
            Attached is the BIOS dump.
            Last edited by OntarioTL; 12-20-2023, 03:42 PM. Reason: No need to store image anymore
            • OntarioTL
              • Feb 2022
              • 59
              Thanks for any help that would have come my way. However, I found a BIOS image that worked and bypassed the password. So I guess it was stored in the BIOS after all. Learn something new everyday.
              I removed my dump so not to gunk up the forum server with unnecessary files.
                • 22278
                The codes at bios-pw do work.Theres a bug with the 6FF1 suffix
                https://www.badcaps.net/forum/troubl...23#post1622423
                3.4. Dell
                Note: The 6FF1 suffix has a bug,use your service tag with the 1F5A or BF97 suffix instead,Example: 1234ABC-BF97 .
                • OntarioTL
                  • Feb 2022
                  • 59
                  3.4. Dell
                  Oh crap! Thanks for the heads up Flea. Of all the suffixes I tried, none that you suggested was attempted. Either way, I got the BIOS file I found on here wiped the pw and also revived another unit that would not post properly.
                  • HK1
                    • Dec 2023
                    • France
                    #169
                    I'm new in this forum and my english is awful.
                    Who can help me with my dump E7470 bios, unlocked by psw ?
                    Dell E7470
                    Motherboard model number : AAZ60 LA-C461P Rev : 1.0(A00) 2015-09-25
                    Thx !!!
                  • Kobo reader
                    • 8
                    • Belgium
                    #170
                    have a problem with my Dell Latitude 7470 with servicetag and suffix:
                    HSBZR72-6FF1
                    Bios-pw.org generates this password for me: iBtf2nnGBBLC0MBz
                    In the BIOS i choose unlock and enter this password with control+enter and control+enter (twice)
                    It seems accepting this password. But after rebooting the laptop the Admin password is back on it and I again need to choose Unlock.
                    The passwords generated with the suffixes BF97 and 1F5A do not work at all.
                    So the initial generated password when choosing the 6FF1 as a suffix is the working password. But it is not saving my changes. Tried BIOS defaults and Factory Defaults already​
                      Vesko356 commented
                      Editing a comment
                      Set your own Admin password, restart and clear the password (type your new password and leave NEW and Confirm New Password fields empty)
                  • Kobo reader
                    • 8
                    • Belgium
                    #171
                    Forgot to mention. Setting own admin password after unlock is not working either. Whatever password i choose it says:
                    "Error setting the password"
                    I can set the systempassword. But is also gone after reboot.
                      Vesko356 commented
                      Editing a comment
                      Downgrade the bios to another version (or upgrade) and try again. If the problem persist upload your bios backup here and someone will remove the password for you.
                  • Kobo reader
                    • 8
                    • Belgium
                    #172
                    I can't boot from any device. Update bios firmware is also behind admin password.
                      Vesko356 commented
                      Editing a comment
                      You can continue with the downgrade/update by entering the Master password when it prompts, or does not accept the password upon entry?
                  • Kobo reader
                    • 8
                    • Belgium
                    #173
                    When entering the BIOS and i enter the generated code with control+enter, i first try to change the Admin password. There it gives me the message "Error setting the password!"
                    If i exit the bios afterwards it reboots the laptop and i get the message: no boot device, press F1 to retry and press F2 to enter setup.
                    If i enter F12 during boot i get the bootmenu. All options are behind the admin password (except Bios setup and diagnostics). If i choose on of the options wich require the admin password i try to enter the generated password: wrong password message.
                      Vesko356 commented
                      Editing a comment
                      I meant a normal bios update through Windows, because you didn't mention that it doesn't boot from any media including SSD.
                      There is a way to do it even in such a case, but I don't want to go into more details. The best approach as I said, in this case is to flash the bios since the standard procedure with a master password doesn't work as it should. Upload your bios backup.
                  • Kobo reader
                    • 8
                    • Belgium
                    #174
                    Thanks for your tips and advice. It doesn't boot from any device. Including windows. Unfortunately.
                    • Kobo reader
                      • 8
                      • Belgium
                      #175
                      Any more advice?
                        Vesko356 commented
                        Editing a comment
                        As I already said upload your bios backup here for unlocking, what do you waiting for?
                    • Kobo reader
                      • 8
                      • Belgium
                      #176
                      I dont have this option. Can't boot from anything. Not even the internal drive with Windows installed.
                    • Stevelht
                      • Slovakia
                      #177
                      could you please generate a master password for Dell Latitude E7470 5LZ7TC2-E7A8?
                      I tried the bios-pw.org generator, but none of the 2 generated password work - Incorrect password entered.
                      Thank you very much!
                      Stefan
                      • qayyum786
                        • Aug 2018
                        • 1959
                        • INDIA
                        #178
                        Stefan
                        Unlock Code 1 [eaR2Jq32FNq46Zb
                        Unlock Code 2 BMErarxZkWZFz697
                        Note: Must Enter "CTRL+ENTER" button after inserting above unlock code. Must use US Standard Keyboard​
                        • Stevelht
                          • Slovakia
                          #179
                          Thank you very much! It was my mistake.
                          The codes weren't working with the built in keyboard, probably because the notebook is german.
                          When I plugged in an external US keyboard, I could succesfully unlock the BIOS with the unlock codes provided.
                          Thank you once again for your help!
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            #180
                            • gizaha
                              by gizaha
                              02-13-2024, 07:18 AM
                            • Sathsul
                              Dell Latitude 5431 issues with dumping bios
                              by Sathsul
                              So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                              The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                              However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                              10-28-2025, 07:49 AM
                              DELL Latitude E7470 Notebook 7000 Specification for Upgrade or Repair
                              This specification for the DELL Latitude E7470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7470 boardview and E7470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                              09-06-2024, 10:00 PM
