Apple Macbook Pro A1278 BIOS Dump
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    #121
    Originally posted by mcwastakenn
    I currently need a MacBook Pro Mid 2010 A1278 (820-2565-A) efi dump. My macbook's efi rom is corrupted. Cant find anywhere else on the internet
    post S/N, ,EMC,post the contents of the bios chip even if it is corrupted..,etc.
    • mcwastakenn
      • Nov 2024
      • 3
      • Philippines
      #122
      My serial number is : W8033A8EATP and the EMC number : 2351
      currently dont have my corrupted bios file dumped
      • Melania Ulibarrie
        • Jan 2025
        • 5
        • Argentina
        #123
        necesito bios funcional macbook pro a1278 820-2936-A EMC 2419
        I need a functional bios macbook pro a1278 820-2936-A EMC 2419
        in English please...
        • peste
          • Dec 2016
          • 13924
          • ROMANIA
          #124
          post the contents of the bios chip even if it is corrupted....post S/N,...
          • Melania Ulibarrie
            • Jan 2025
            • 5
            • Argentina
            #125
            S/N bios MXIC MX25L6406E and S/N Macbook D92FCDY3DH2G
            • peste
              • Dec 2016
              • 13924
              • ROMANIA
              #126
              The bios you posted is longer, be careful how you write this one..
              • peste
                peste commented
                Editing a comment
                wait for a response where you first post...don't post everywhere..
            • caputcha
              • Oct 2020
              • 13
              • Morocco
              #127
              MacBook A1278 (820-3115-B) flashed some online dumps but not turning on just fan turning on when write back original dump same problem
              black screen + fan turning and stops
              SN :C1MQ73Z2DTY3 EMC 2554
              any help will be appreciated
              • peste
                • Dec 2016
                • 13924
                • ROMANIA
                #128
                try..
                • caputcha
                  • Oct 2020
                  • 13
                  • Morocco
                  #129
                  try..
                  I tried it not working
                  • purwanto axtp
                    • May 2024
                    • 31
                    • Indonesia
                    #130
                    macbook pro 2012
                    820-3115-b
                    emc : 2554
                    Hi friend, I need a solution for MacBook A1278 820-3115-B. It only beeps; initially, it was completely dead. I have replaced the TPS51125 and several other components. It turns on now, but there is only a beep sound and no display.
                    • caputcha
                      • Oct 2020
                      • 13
                      • Morocco
                      #131
                      Nice work — sounds like I successfully revived My MacBook! 🎉
                      Let’s restate and clarify what I did, because I am basically describing a common BIOS chip recovery process:
                      I bought a new SPI flash chip to replace the old one on my MacBook’s logic board.
                      I took My patched backup of the original firmware (edited with HxD, the hex editor).
                      Then flashed that firmware onto the new chip.​
                      The EZP programmer couldn’t verify the data after writing (common issue — it sometimes struggles with certain chip IDs or voltages).​
                      I switched to a CH341A programmer, which successfully wrote and verified the firmware.​
                      After that, the MacBook came back to life ! EFI password gone forever.
                      The problem was indeed with the EZP programmer’s verification process, not my file or chip. The CH341A did the job properly.​
                      • Ahari
                        by Ahari
                        I...
                        08-13-2025, 06:12 AM
                      • mkdj
                        by mkdj
                        Dear all,
                        10-19-2025, 04:41 AM
                      • Habble7
                        by Habble7
                        Suspected Cause:
                        Troubleshooting Attempts:
                        05-22-2025, 07:28 AM
                      • haitham sharabati
                        [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                        by haitham sharabati
                        Hello engineers 😀,
                        I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                        🔧 Device Info:
                        - Model: HP 15-da2007ne
                        - Product Number: 8XF55EA#ABV
                        - Serial Number: CND0338P0D
                        - CPU: Intel Celeron N4000
                        - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                        💀 Problem:😅
                        - Device shows “Administrator Password”...
                        08-07-2025, 04:54 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
