Bios Dump Toshiba L50-A-1CU PSKK6E
  • DsB_79
    • May 2013
    • 16
    • Portugal
    Hi, i need a bios dump from a working laptop model Toshiba L50-A-1CU PSKK6E, can someone help.
    Regards,
    Diogo.
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Bios Dump Toshiba L50-A-1CU PSKK6E
    Try this
    • DsB_79
      • May 2013
      • 16
      • Portugal
      Hi, this is only one file i have two chips do i need to programm the two chips, or only need to programm the main one?
      • DsB_79
        • May 2013
        • 16
        • Portugal
        Hi, the laptop is working again but in the device manager i have code 43 for the NVIDIA graphic card 740m and the card reader of the laptop is not working in the device manager appears invalid device descriptor, can this be any thing to do it with the BIOS update.
        Can some onde help me debug this issue.
        Regards,Diogo.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          since there is no working bios dump available on net for free
          dump your bios so i can try to fix it usig parts from web updates from toshiba
          simetimes i manage to fix problems
          dump both chips pls
          Im Back... sort of...
          • DsB_79
            • May 2013
            • 16
            • Portugal
            Hi, ok here is the bios dump, if you or anyone can fix this, all of you are a live savers.
            Thanks,
            Diogo.
            • DsB_79
              • May 2013
              • 16
              • Portugal
              This may help, the pcb board has reference vsg mb rev 2.1 and part number is pskke-03m06cep.
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                this board has 2 bios
                one is PCH bios and you posted it, its 2 mb
                other should be main and 4mb (but you did not post it so i cant be sure)
                here is main dump (4mb bios)
                make backup before anything
                • DsB_79
                  • May 2013
                  • 16
                  • Portugal
                  Hi, Ala_Borde
                  sorry my mistake, here is the two files the main one and the phc.
                  Regards, Diogo.
                  • DsB_79
                    • May 2013
                    • 16
                    • Portugal
                    Hi, i have some good news, i manage to flash back the original 2mb pch bios and the invalid device descriptor is gone from the device manager my only problem now is the graphic card the nvidia always appears with code 43, i have install the latest driver from nvidia site but no luck. My question is, will the main bios has anything to do with this problem on the graphic card? This graphic card has the optimus tecnology.
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      try this, flash both chips, remove cmos battery
                      and of course install all drivers and utilities given by toshiba for this model, and if all works well try then to update driver from nvidia
                      • DsB_79
                        • May 2013
                        • 16
                        • Portugal
                        Hi, i have flash the two bios and the same problem code 43 on the graphic card and with this bios the usb invalid descriptor appears again.How can i see if the original bios has a error so i can fix it or see it.
                        Regards, Diogo.
                        • DsB_79
                          • May 2013
                          • 16
                          • Portugal
                          Hi, i have manage to flash back the original bios file now i only have code 43 on graphic card, i suspect that the problem relies on the chip of the graphic card. Thanks, all for the help so far.
                          Regards, Diogo.
                          • Ghost18_07
                            Zakaria
                            • Mar 2018
                            • 73
                            • Algeria
                            Thanks, after all those years i still confirm that it's a working Bios 🤣
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • DProf.
                              TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                              by DProf.
                              High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                              Toshiba Dynabook T55/AB, PT55ABP-BJA2
                              MODEL NAME. Satellite L50-D series
                              P[ART NO PS57MN-00600R
                              Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                              09-26-2024, 04:30 AM
                            • Ziome3eknh
                              Please bios dump toshiba dynabook satellite pro c5-e-104
                              by Ziome3eknh
                              Hello, I need to fix the BIOS dump or some other working one
                              Model: Toshiba Dynabook Satellite pro C5-E-104
                              SN: 70014063A
                              Motherboard: IP3_KN16R_MB_V20_200326A
                              Platform intel Core i5 8gen
                              Attached dump​...
                              04-24-2025, 11:35 AM
                            • DynaxSC
                              by DynaxSC
                              11-17-2023, 10:56 AM
                            • grimacelord
                              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                              by grimacelord
                              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                              Motherboard model number: DA0PAMB46A1 REV: A
                              Secondary motherboard model number: 0PAB
                              SKU: 685K4UA
                              Serial number is: 5CD3223BJP
                              Recently reflashed this laptop with latest BIOS and once...
                              05-07-2024, 08:06 AM
