HP mini 210-1134TU bios dump needed.
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Hi.
    Does anyone have bios dump of this model?
    Tia
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: HP mini 210-1134TU bios dump needed.
    i extracted this from update.often works.rename .bin and write your chip
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      thanks
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • TacticalFahrrad
        [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
        by TacticalFahrrad
        I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
        06-30-2025, 04:09 AM
      • vinaypundith
        Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
        by vinaypundith
        I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
        So, I'm looking for a BIOS dump for this machine - a 16MB one....
        08-03-2024, 12:32 PM
      • James Maxwell
        HP DM1-4000er Bios Dump needed
        by James Maxwell
        I badly need bios dump for HP DM1-4000er,
        Model: HP DM1-4000er
        Motherboard: DA0NM9MB6D0 REV.D
        Product: QJ490EA#ACB
        Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
        10-28-2024, 05:38 PM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
