Bios password From Bios File
This topic is closed.
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    • smd electronics
    how can a password can be retrived from a password protected bios file?
    any idea , please.
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: Bios password From Bios File
    any idea , please.
    Its hard to retrieved password bios,
    but probably to clear a bios password file is more easy ...
    • masud
      • Jul 2011
      • 317
      • Bangladesh
      • smd electronics
      how to do that?
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        how to do that?
        I cannot explain for the detail, you need many trial for that...
        but if you sure the password is store in the bios chip,
        After you get lockedbios file, and you must get update file from vendor, i usually use uefi tool and hexeditor, to mix that files...
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          in most cases you have on vendor support site bios with no password, then hex copy serial and model info in unprotected file and flash that file
          or flash file from other laptop with no password
          Im Back... sort of...
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            right Donald,
            but not all vendor give full bios, just update bios part,...
            This is my experience password bios case in this month,when there is hard to find CLEANDUMP bios file out there...
            this notebook is :
            LG-GRAM 14Z950 PASSWORD POWER ON;3x wrong input, the system will be disabled and no hashcode...
            i have no schematic,but i am sure if the password is store in the bios chip MX25L12873F,
            Tools:
            -any SPI Programmer
            -UEFITool
            -HexDump
            -7Zip
            in short words....
            1. With any Spiprogrammer(i use the olddevice LPT-NANOBIOS+willem software),you'll get the file DUMP.BIN(16MB)
            2. Find the update file (14Z950FB_x64.RAR)from LG site, extract 14Z950FB_x64.RAR with 7Zip.
            Find the \\BIOS\14Z950FB_x64\.rsrc\1042\FILE\177 (7.641KB) (no extensions)...177 file is updatefile.
            3. Now you have 2 files : DUMP.BIN(16MB) and 177(7MB)
            4. Open that 2 files with uefitool(to verify) if the biosregionfile from 2 files is exactly...
            you will see if the dumpfile DUMP.BIN(16MB) is full bios with (including descriptor region,me region,padding,bios regions(8files)),but for the 177(7MB) only bios region with padding, and 7files.
            Now compare 2 files, and find the identical files module from biosregion.... i got 6 files identical (guid name and size)
            5. - With UEFItool Replace "6 files identicalbiosregion" DUMP(16MB) with extracted "6 files identicalbiosregion" from 177(7MB)
            - Or you can use Hexeditor to copy/insert biosregion with help detail from uefitool (to get exact offset and size biosregion file)
            6. Save this file as newfile.bin(16MB), now you can close uefitool-177(7MB).
            7. Remember if newfile.bin(16MB) is blank serial nr,etc....to insert new serial nr,you can use LG_DMItool (like HP using NBDMIfit),,
            8. if you dont have dmitool, For the Serial Number etc,(writedown from bottom case),And you can use uefitool again to search sn from DUMP.BIN(16mb) for replace again to newfile.bin(16MB) OR you can use HEXeditor....
            your file ready to flash to chip...
            ##Just Sharing, Hope this way can help someone to Clear the biosPassw
            • nova100
              • Feb 2017
              • 35
              • Egypt
              is there any way to see the password in rom file by the hex editor
              and if it wich line
              i hope to find my request here
                • 31632
                what machine is it?
                • nova100
                  • Feb 2017
                  • 35
                  • Egypt
                  dell inspiron 15 3558 bios password
                  already programed it with two file bios same board id
                  the issues the machine boot up after 16 second so i need to know if there is a way to get the password from the original machine bios.
                  by the way it work normal with original dump with the password on it
                    • 31632
                    some laptops can reset the password using test-points on the board.
                    try to find a service manual.
                    • yamish23
                      • Jul 2019
                      • 8
                      • philippines
                      where to download the uefi tool?
                        • 23697
                        Here.
                        • charafmak77
                          • Oct 2017
                          • 84
                          • jijel
                          Can you explain the method to us by video
                          • skysurf
                            • Apr 2015
                            • 21
                            • Portugal
                            hi, how i use wxhexeditor to find the serial number of pc ? and mac address and part number ?
                            thanks
                            • smiley60
                              • Jul 2021
                              • 43
                              • UAE
                              where i can find more about bios editing
                              can u explain that for me
                              • shindu41
                                • Oct 2016
                                • Philippines
                                hello sir how can i search the serial number in bios file using hexeditor...thank you
                                • abdoelhosseiny@aol.com
                                  • Jun 2020
                                  • 37
                                  • UEA
                                  Good question
                                  i hope someone help us
                                  • kwabena45
                                    • Jun 2021
                                    • Ghana
                                    use ufi tool ne alpha 32, drag and drop ufi bin and go to the bios section click expand and search for vssstore , expand and u have all those things in there. example csn , sku and others.
                                    • Magnusa2
                                      • Jul 2017
                                      • 66
                                      • India
                                      plz explain in video format
                                      • ramadanemrullah
                                        • Aug 2023
                                        • 16
                                        • Türkiye
                                        hello my original bios but i can't find the password how can i see the password of the bios
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • to5it0
                                          by to5it0
                                          10-24-2025, 01:35 AM
                                        • Nopslide
                                          HP Omen 15-dh0052nf power-on & bios password
                                          by Nopslide
                                          Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                          My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                          Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                          04-01-2024, 04:27 PM
                                        • outsider
                                          Panasonic FZ-G1 MK5 - BIOS password returning
                                          by outsider
                                          Hello
                                          I removed the BIOS password thanks to the help of one of the friends of this forum.
                                          https://www.badcaps.net/forum/troubl...61#post3637661
                                          The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                          06-17-2025, 12:51 AM
                                        • MONDTECH
                                          x1403za r2.1 bios uefi password any one clear my bin file
                                          by MONDTECH
                                          serial NBN0CV10581747C
                                          board id X1403ZA MAIN BOARD R2.1
                                          bin file
                                          https://drive.google.com/file/d/1jBD...ew?usp=sharing
                                          12-12-2025, 10:40 PM
