Toshiba Setlite C850-A989 plf/plr/csf/csr uma mb rev 2.1 bios BIN FILE NEED
  • maqbool
    • Dec 2012
    • 17
    • pakistan
    Hi guys
    INTEL GRAFIC CARD
    DUAL CORE
    bios .bin file need
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: Toshiba Setlite C850-A989 plf/plr/csf/csr uma mb rev 2.1 bios BIN FILE NEED
    chek the SEARCH field !!!
    • maqbool
      • Dec 2012
      • 17
      • pakistan
      Not found
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        https://www.badcaps.net/forum/attach...0&d=1425472084
        rename fd to bin and flash
        Im Back... sort of...
        • maqbool
          • Dec 2012
          • 17
          • pakistan
          Thanks partner, I'll try it.
          • Zaraki7777
            • Sep 2017
            • 174
            Thank you
            • abdulhashim
              • Jul 2015
              • 22
              • UAE
              Thank you
              • Layth
                • Dec 2014
                • 30
                • iraq
                Thank you
                • tamas
                  • Aug 2014
                  Hello there!
                  Is anybody has boardview and schematich for the above model. please?
                  • karem adil
                    • Oct 2016
                    • 37
                    • alex
                    thanks
                    • rachid1271
                      • Jul 2014
                      • 5
                      • maroc
                      Thank you very much
                      • msl77
                        • Jun 2014
                        • 10
                        • yemen
                        Thank you very much
                        ///yes
                        • to5it0
                          by to5it0
                          10-24-2025, 01:35 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                        • maanee11
                          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                          by maanee11
                          Hello Everyone,
                          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                          In the website, you can only see specs etc.
                          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                          11-08-2025, 04:08 AM
                        • m1ch43lzm
                          by m1ch43lzm
                          Hi everyone
                          09-06-2025, 05:47 PM
                        • HOHA
                          BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                          by HOHA
                          Hi can you help me
                          I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                          IP3_TN16S_MB_V30_20210901A
                          This is the old BIOS file, it is corrupted​...
                          10-20-2024, 08:22 AM
