Yoga S11 need bios (black screen)
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Hi i need bios for this yoga s11 please . old dump attached .
  • faik26
    • Sep 2015
    • 10
    • TÜRKİYE
    Re: Yoga S11 need bios (black screen)
    try this.
    • mixdob
      • Jul 2014
      • 10
      • egypte
      thxxxxxxx
      • gcomputers
        • Apr 2013
        • 509
        • Albania
        Originally posted by faik26
        try this.
        Thanks, i tried but the same problem no video.
        • Touqeersiddiqui
          • 19
          • Pakistan
          thanks
          • mitchw
            HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
            by mitchw
            Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
            After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
            After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
            I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
            04-29-2025, 03:45 PM
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
          • BlueNitesFire
            I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
            by BlueNitesFire
            So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
            03-08-2025, 03:49 PM
          • AgustinLorenzo
            [BIOS REQUEST] HP Pavilion 15-BS521TU - Black screen after update BIOS to F.73
            by AgustinLorenzo
            Hi boys,
            This is my first post in BADCAPS and I hope I don't make any mistakes and give the correct explanations.
            Yesterday a friend brought me this laptop home to expand the RAM to 16GB of RAM and update it since it had been abandoned recently.
            Everything was fine, until I made the mistake of updating the BIOS to version F.73 from version F.24, since after according to HP "updating correctly" the laptop never worked again, leaving the screen black but the fan is working and the light of M.2 is on.
            After having carried out all the frequent...
            10-15-2023, 07:31 AM
          • amennone
            Acer A315-24p-r2km , black screen. Bios
            by amennone
            Acer A315-24p-r2km Acer N23C3 snid: 32400005934 s/n NXKDEET00B3240003B3400 Main: IH5JM LA-M611P Rev: 1A
            As per the title, the screen remains black. When the power button is pressed, the blue LED lights up, but the screen is black.
            With an external monitor and HDMI output, there is no image. I loaded the following bins, same situation: ACER_A315_24P_IH5JM_LA_M611P_REV_1A_2022_08_22_WORKING_BIOS_100% IH5JM120.bin from this address https://www.badcaps.net/forum/troubl...a-m611p-rev-1a With the RT 809F programmer, I can't read the contents of the original XMC 25QU128CH1Q SPI, I get the...
            07-31-2025, 04:19 PM
