alienware M14X bios
  • alihomee
    • Dec 2012
    • 1599
    • malaysia
    alienware M14X bios
    need bios file for this model mobo num is QBLBO LA-8381p rev :1.0
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: alienware M14X bios
    Try whit this bios
    but i m not sure that working for you
    because the number of mother is different
    • alihomee
      • Dec 2012
      • 1599
      • malaysia
      this is for different notebook my file is 8mb
      • alihomee
        • Dec 2012
        • 1599
        • malaysia
        need bios urgent
        • dellxps15
          • Feb 2014
          • 1598
          • italy
          i have it. gimme some minute. can u make some detailed picture of whole board up and down ?
          have that m14x with discrete problem. when it detect discrete vga (bga chip put brand new) it start windows , but after some windows loading i have black screen. all ok if i use battery only and it use intel gpu.
          i think i have lost some small component on the board so need some detailed board picture to see if some component is visible misisng. if u can make picture in 4-6 part of each side would be great.
          notebook is at m8 house for bga replacement, but bios dump should not be a problem.
          • dellxps15
            • Feb 2014
            • 1598
            • italy
            i got my alienware back from friend and can make dump for u. do u still need it ?
            • cyberhack
              • Feb 2013
              • 466
              • Uk
              Just got this from a chinese site hope it works for you.
              • dellxps15
                • Feb 2014
                • 1598
                • italy
                here is my bios dump. hope it works for u
                • alihomee
                  • Dec 2012
                  • 1599
                  • malaysia
                  thanks you very much this is working
                  • rager007
                    • Feb 2016
                    • 106
                    • Usa
                    thank you
                    • msl77
                      • Jun 2014
                      • 10
                      • yemen
                      goood
                      • to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                        by to5it0
                        Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                        I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                        This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                        I have opened the laptop and identified the main BIOS chip...
                        10-24-2025, 01:35 AM
                      • Citymin
                        by Citymin
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
                      • maanee11
                        Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                        by maanee11
                        Hello Everyone,
                        I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                        It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                        In the website, you can only see specs etc.
                        I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                        11-08-2025, 04:08 AM
                      • m1ch43lzm
                        Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                        by m1ch43lzm
                        Hi everyone
                        I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                        Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                        Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                        There's also an extra OTP Secu.R...
                        09-06-2025, 05:47 PM
                      • Forest79
                        by Forest79
                        However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
                        07-23-2023, 07:39 AM
