Quanta dar33hmb6a0 rev a Bios
  • polytek
    • Dec 2013
    • 497
    • TUNISIA
    Hi all;
    the laptop no display cpu is in board i need bios bin file for this motherboard
    QUANTA: DAR33HMB6A0 REV:A
  • kazia
    • May 2015
    • 145
    • indonesia
    Re: Quanta dar33hmb6a0 rev a
    my be this match..
    • polytek
      • Dec 2013
      • 497
      • TUNISIA
      thanks a lot , i will try this now;
      • francisruban
        • Nov 2014
        • 10
        • India
        sir, i tested above file, its working , thanks a lot
        • polytek
          • Dec 2013
          • 497
          • TUNISIA
          Originally posted by kazia
          my be this match..
          by the way thanks for my friend kazia
          • charafmak77
            • Oct 2017
            • 81
            • jijel
            Re: Quanta dar33hmb6a0 rev a Bios
            • essamali
              • Feb 2012
              • 9
              my be this match..
              working very well
              thanks
              • rakibul85
                • Mar 2017
                • 26
                • Bangladesh
                Originally posted by essamali
                working very well
                thanks
                thank you
                • ahmedmeer
                  • Nov 2023
                  • 14
                  • dubai
                  Originally posted by polytek
                  Hi all;
                  thanks
                  • to5it0
                    by to5it0
                    10-24-2025, 01:35 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
                  • maanee11
                    Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                    by maanee11
                    Hello Everyone,
                    I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                    It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                    In the website, you can only see specs etc.
                    I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                    11-08-2025, 04:08 AM
                  • m1ch43lzm
                    by m1ch43lzm
                    Hi everyone
                    09-06-2025, 05:47 PM
                  • Forest79
                    by Forest79
                    07-23-2023, 07:39 AM
