Need bios Acer Z5W1M La b511p Rev.1.0
    • 21899
    Re: Need bios Acer Z5W1M La b511p Rev.1.0
    Originally posted by nabilgo
    this for programming new i/o
    Check post #17 ,the bios.bin is bios ,EC.bin is the i/o
    • fyaagoub
      • 269
      • maroc
      Thanks a lot
      • zurvanielle
        • Feb 2017
        • 137
        • Philippines
        thanks ridamouh, it works...
        • alihomee
          • Dec 2012
          • 1594
          • malaysia
          Es1-511
          i tried almost all files available on this forum....only one file works good and trackpad work and shows option for trackpad in bios.....accidently i tried to update and notebook goes dead....now i used all files no one gives the trackpad option in bios .....need help its confirm bios issue as i tested....last good file is attached but this file also does not show trackpad option in bios....mobo code isLA-B511P
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            Re: Es1-511
            post the originaL dump ...Post your S/N
            • alihomee
              • Dec 2012
              • 1594
              • malaysia
              #26
              Re: Es1-511
              ori file not available so sorry for that
              s/n:42116220634
              • alihomee
                • Dec 2012
                • 1594
                • malaysia
                #27
                any help........
                • alihomee
                  • Dec 2012
                  • 1594
                  • malaysia
                  #28
                  if any one having old file with trackpad setting in bios ...plz shear
                  • alihomee
                    • Dec 2012
                    • 1594
                    • malaysia
                    #29
                    waitting so long any help ....
                    • alihomee
                      • Dec 2012
                      • 1594
                      • malaysia
                      #30
                      any one have a file ....
                      • alihomee
                        • Dec 2012
                        • 1594
                        • malaysia
                        #31
                        ok i found it on a website and flash and trackpad works and shows in bios setup file is attached
                        • m0seba
                          • Mar 2016
                          • 38
                          • egypt
                          #32
                          Help with Bios Acer Aspire E 15
                          hey guys
                          I get laptop Acer Aspire E 15 with no power
                          After I flashed the BIOS, the device turned on but with black screen
                          first of all if anyone have a original BIOS tested for this Motherboard model ( Z5W1M La b511p )
                          also when i flash the BIOS i found this msg on the software program
                          that told me i must use the 1.8v adaptor
                          actually i never seen this MSG before
                          for info i have a MiniProTL866CS Programmer
                          Last edited by piernov; 04-19-2022, 02:31 AM. Reason: remove useless formatting and broken images
                          • m0seba
                            • Mar 2016
                            • 38
                            • egypt
                            #33
                            Re: Help with Bios Acer Aspire E 15
                            Originally posted by m0seba
                            hey guys
                            anyone guide me PLZ ??
                            • peste
                              • 13599
                              • ROMANIA
                              #34
                              yes .. you need a 1.8v adapter ... which you can buy, or you can do it in an hour .... if you have what you need..the schema is given to you by the programmer when he tells you, that you must use the 1.8v adapter.
                              • dqtech
                                Badcaps
                                • Jul 2018
                                • 639
                                • N/A
                                #35
                                thanks
                                • Ericwins
                                  • Dec 2021
                                  Try this one,extracted from official acer bios.If this one doesn`t work its not a bios problem.
                                  Hi, Where is the EC flash chip on this motherboard? I flashed the bios but cant find the ec chip anywhere on the board. thanks
                                  • peste
                                    • 13599
                                    • ROMANIA
                                    #37
                                    EC is in the I/O chip...
                                    • EbrahimSiami
                                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                      by EbrahimSiami
                                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                      **What I have tried so far:**
                                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                      07-02-2025, 02:31 PM
                                    • Wg188
                                      ACER Veriton Z4660G AIO bios help
                                      by Wg188
                                      I have an Acer veriton Z4660G all in one pc,
                                      Model: Z4660G-I5850H1 (VZ4660G_W)
                                      Need bios dump and schematic would save my life !
                                      to make a long story short I bought this all in one used
                                      with a broken lcd, with the objective of making a custom desktop out of it
                                      ,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...
                                      06-17-2023, 02:20 PM
                                    • macabook
                                      by macabook
                                      🧩 Initial Issue
                                      07-24-2025, 02:17 PM
                                    • James194zt
                                      Acer Nitro 50-640E Corrupted BIOS Dump
                                      by James194zt
                                      My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
                                      All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
                                      04-28-2025, 03:29 PM
                                    • ub6ib969
                                      Acer Predator PO3-650 BIOS can someone help convert .CAP to .BIN ?
                                      by ub6ib969
                                      Model Number: PO3-650
                                      Part Number: DG.BK4AA.006
                                      Serial Number : 33400117730
                                      BIOS IC : XM25QH256C
                                      I have uploaded the bios from the acer website and the extracted bios from the board. Any help would be appreciated...
                                      07-02-2025, 03:51 PM
