Apire es1 131 bios
  • Cavedud
    • Jun 2015
    • riau
    Apire es1 131 bios
    please help me i need bios dump Apire es1 131.. ty
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: Apire es1 131
    backup the old one, try this...(bios voltage 1.8v)
    • Cavedud
      • Jun 2015
      • riau
      Re: Apire es1 131
      thank you mr meritosari...
      • skavioce
        • May 2015
        • 34
        • morocco
        Re: Apire es1 131
        think you brather
        • seron
          • Apr 2017
          • 10
          • türkiye
          Re: Apire es1 131
          Thank you.
          • iP24Nk
            • Oct 2017
            • Indonesia
            Re: Apire es1 131
            Thank you. Thank you. Thank you. Finally it's unbricked.
            Terima kasih mau berbagi. Semoga Tuhan membalas dengan kesehatan dan rezeki yang berlimpah. Amin.
            • bilaloga
              • Mar 2018
              • Saudi Arabia
              Re: Apire es1 131
              How did you manage to unbrick your device? i have the same problem.
              • bilaloga
                • Mar 2018
                • Saudi Arabia
                Re: Apire es1 131
                thank you i used this bios for my laptop and now its working fine.
                you have to program two ICs one above and one below the heat sink.
                • vougheart
                  • Jul 2020
                  • 65
                  • philippines
                  Re: Apire es1 131
                  tested need flash 2 file
                  thank you
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • mkdj
                    by mkdj
                    Dear all,
                    10-19-2025, 04:41 AM
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • haitham sharabati
                    by haitham sharabati
                    Hello engineers 😀,
                    🔧 Device Info:
                    - Model: HP 15-da2007ne
                    - Product Number: 8XF55EA#ABV
                    - Serial Number: CND0338P0D
                    - CPU: Intel Celeron N4000
                    💀 Problem:😅
                    08-07-2025, 04:54 AM
                  • Citymin
                    by Citymin
                    S/N : 5RNK9FFT70...
                    08-05-2025, 05:12 AM
