IBM T61 bios and security eprom dump
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    HI
    To replace damaged security eprom , I'm searching a bios and eprom dump of the same machine or a method to solve this issue.
    thanks
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: IBM T61 bios and security eprom dump
    repalce mosfet p24s08 near docking station slot remove supervisor password.
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      I have already replaced the eprom p24s08. But if I replace the EPROM without program it with a code, the system compares this code with the same inside the bios and if there is no match, it stops on an error.
      The only way, since the EPROM is empty, is to reprogram the bios and the EPROM with a dump taken from the same motherboard without bios password.
      Remove the eprom work only with certain models.
      thanks
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        its working without program find the scrap board and replace the mosfet t60/ t61 and many c2d board this mosfet p24s08 find without password and replace its working no need to program this fet.
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          Thanks for info, but the notebook is too old and I haven't a deat mobo, buy it on ebay around 20-25 € is too expansive for my customer.
          • sriram
            • Dec 2017
            • 6
            • India
            l want lenovo x61 thinkpad bios file
            • sahaj digital
              SAHAJ PAL
              • Oct 2016
              • 17
              • INDIA
              sir t61 bios
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • haitham sharabati
                by haitham sharabati
                Hello engineers 😀,
                🔧 Device Info:
                - Model: HP 15-da2007ne
                - Product Number: 8XF55EA#ABV
                - Serial Number: CND0338P0D
                - CPU: Intel Celeron N4000
                💀 Problem:😅
                Yesterday, 04:54 AM
              • Citymin
                by Citymin
                S/N : 5RNK9FFT70...
                08-05-2025, 05:12 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • MDSI
                HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                by MDSI
                I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                Details:
                Model : HP OMEN 17-an012nf
                Motherboard Part Number : DAG3BAMBAF0 REV : F
                Serial Number (S/N) : 5CD7280D51
                BIOS chip : Winbond W25Q64VSIQ
                Programmer : EZP2023+
                Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                I already...
                07-28-2025, 07:11 AM
