Need bios dump for Lenovo Thinkpad X240
  • poweron
    • May 2019
    • 371
    • italy
    #41
    Re: lenovo x240
    Originally posted by peste
    try..
    tried, it turns on but with a black screen
      • 21145
      Re: lenovo x240
      try this one
      • poweron
        • May 2019
        • 371
        • italy
        #43
        Re: Need bios dump for Lenovo Thinkpad X240
        this works but it asks me for the svp supervisor password and I can't enter the bios by pressing F1
          • 21145
          There`s no pass in the bios i posted,its in the ec.Use a patched version now
          https://www.badcaps.net/forum/showth...=87588&page=41
          • poweron
            • May 2019
            • 371
            • italy
            #45
            yes thanks, but since I don't have much practice with these operations could you explain to me what should I do? I have to unsolder the bios chip again and with ch341a remove the bin you sent me and put the generated patch then following the procedure put back the bin that was there?
            • poweron
              • May 2019
              • 371
              • italy
              #46
              can i use this?
              or should i pacher my bios?
              • platinumsteel
                • May 2019
                • 234
                • Trinidad&Tobago
                #47
                Lenovo X240 Late Display
                Hi guys i have a Lenovo x240 NM-A091 that gives me a very late displ;ay but it works fine .I have provided the working dump it was using.Is it possible you guys can maybe clean the Me Region or repair it for me Thanks Much.
                • peste
                  • 12933
                  • ROMANIA
                  #48
                  Re: Lenovo X240 Late Display
                  try.
                  • platinumsteel
                    • May 2019
                    • 234
                    • Trinidad&Tobago
                    #49
                    Thanks again Master Peste . It boot's like a Rocket Now.
                    • poweron
                      • May 2019
                      • 371
                      • italy
                      #50
                      can i use this?
                      I have performed the procedure and the problem is solved
                      Thank you
                      • insonmania
                        • Mar 2021
                        • 9
                        can i use this?
                        thanks bro
                        it's working
                        • andresi
                          • Nov 2020
                          • 153
                          • INDONESIA
                          #52
                          sir can you help me, i have lenovo x240 bios pasword lock, can you fix it to me tq sir
                            • 21145
                            there`s a patched version, read the instructions carefully https://www.badcaps.net/forum/showthread.php?t=81573
                            • andresi
                              • Nov 2020
                              • 153
                              • INDONESIA
                              #54
                              ty sir
                              • andresi
                                • Nov 2020
                                • 153
                                • INDONESIA
                                #55
                                • Lornet
                                  • Mar 2021
                                  • 27
                                  • France
                                  #56
                                  I've trouble with a X240 : when I plug it, I see the green power led blinking four times (not three). When I try to boot it, I only see the keyboard leds lighting one time, then the green power led blinking four times once again and nothing else.
                                  I've flash the bios with a "generic" bios found on the net : the laptop start (after a long time because of ME Region I suppose). Then I've tried to change date on the bios but it was impossible because of a supervisor password (and impossible to enter the bios and see it after three wrong password). I've come back to the X240 few hours later and now, the laptop doesn't boot at all : when I plug the charger, the laptop try to boot automatically and the green led power button still lighetening without anything else.
                                  I've try to flash once again the generic bios but the laptop stil try to boot itself without any result : no beeps, no logo, etc...
                                  What can I do ?
                                  Thanks for your reply and best regards.
                                  PS : I've make several copy of the original bios and always verify 2 times each flash and copy.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11874
                                    #57
                                    Post your original bios bin file here. Maybe someone else will help you.
                                    • Lornet
                                      • Mar 2021
                                      • 27
                                      • France
                                      #58
                                      This is the original bios : can someone try to fix it ?
                                      • hoaca388
                                        Badcaps
                                        • Jan 2022
                                        • 11874
                                        #59
                                        Originally posted by lornet
                                        this is the original bios : Can someone try to fix it ?
                                        Code:
                                        253973
                                        • Lornet
                                          • Mar 2021
                                          • 27
                                          • France
                                          #60
                                          Originally posted by hoaca388
                                          Code:
                                          253973
                                          Thanks but not working : when plugged, the green led on power button blink four times then the laptop "starts" -green led always lightening and the fan is on- but nothing on the sreen, staying always black after a long time.
                                          Any other idea ?
                                            Lenovo ThinkPad X240 Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X240 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X240 boardview and X240 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                            09-06-2024, 08:35 AM
                                            09-06-2024, 06:14 AM
                                          • Joluvillas
                                            Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                            by Joluvillas
                                            Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                            06-18-2024, 10:35 PM
                                          • 1g0r
                                            Lenovo ThinkPad L15 G3 Bios 1 IC conductor track
                                            by 1g0r
                                            First, the data in brief:
                                            Manufacturer: Lenovo
                                            Model: ThinkPad L15 G3 21C3-0016GE
                                            motherboard: LG4 LT5 ADL RT UMA MB 8L - 448.0PZ26.0011
                                            IC Bios 1: MX77L25650F
                                            IC Bios 2​: MX25L25673G
                                            EC Chip: NPCX997KAABX
                                            So far I've been a silent reader, but now I need your help
                                            I bought a laptop. The seller said the bios was locked. I was looking for a way to remove this ban.
                                            I then got the CH341A and pulled the corresponding files from here https://www.badcaps.net/forum/troubl...evices-and-ele...
                                            The laptop was brought in with a BIOS problem and a password. After reading the dump, the information was damaged. I ask for help in the BIOS with a clean ME region. Motherboard 213035-1. Serial number: PW+04e998, Type number: 21c3-0016ge
                                            01-18-2025, 02:39 AM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
