win8 key from bios dump
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    I have reprogrammed an asus bios chip with a dump file taken from the internet.
    I made a copy of the corrupt original bios .
    I need, if is possible, to inject the win8 product key from corrupt bios to the working bios, or extract it and validate windows after installation .
    I read it's possible on working pc with read acpi table with a tool as rw everything , but if I have only a bios dump ?
    thanks
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: win8 key from bios dump
    If it's possible, the procedure is not public, i think !
    If you have the untouched original hdd, pc should boot and then with a software you can get the key !
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      thanks
      Upload the dump. I know how.
      Follow the white rabbit.
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        The notebook's owner wants everything to return as before. because he wants to sell the notebook.
        Unix like os is well only for certain use.
        I use ubuntu 15 but, for example, to install a program is not intuitive as with windows os and if some things go bad..... most tools for certain hardware are not available, for example for my bios programmer or for my oscilloscope.
        I don't want to go off thread...
        • sopik78
          • Nov 2013
          • 519
          • Czech Republic
          Any new procedure how to retreive the product key?
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            by haitham sharabati
            Hello engineers 😀,
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            💀 Problem:😅
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
