emachines D640 bios dump needed
  • salawayon
    • Nov 2012
    • 578
    • philippines
    Board infos: JE40-DN MB
    AMD based system...
    No display problem on this one...
    Thanks..
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: emachines D640 bios dump needed
    try this but make backup ofd old bios
    Im Back... sort of...
    • salawayon
      • Nov 2012
      • 578
      • philippines
      Hi... i've tried the file on 2 units... but still no display... and got a warning "Some data out of memory size" on my programmer.
      Thanks...
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        yes, i made mistake cutting a file
        here is a proper file
        second file is dump from working machine
        • salawayon
          • Nov 2012
          • 578
          • philippines
          Thanks.. but a sad ending.. it doesn't cure the problem... tried both files on both unit but still no display.. maybe a busted vchip already..
          Thanks...
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
          • vinaypundith
            Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
            by vinaypundith
            I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
            So, I'm looking for a BIOS dump for this machine - a 16MB one....
            08-03-2024, 12:32 PM
          • James Maxwell
            HP DM1-4000er Bios Dump needed
            by James Maxwell
            I badly need bios dump for HP DM1-4000er,
            Model: HP DM1-4000er
            Motherboard: DA0NM9MB6D0 REV.D
            Product: QJ490EA#ACB
            Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.
            10-28-2024, 05:38 PM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
