Macbook A1278 EMC 2555 board 661-6158 Bios wanted
  • Mario
    • Sep 2007
    • 64
    Hi i have a EFI firmware locked macbook 2011. Does anyone have a clean firmware for this mac or can remove pw? Attatched is my old bios.
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Macbook A1278 EMC 2555 board 661-6158 Bios wanted
    Apple Part Number:
    661-6158
    Manufacturer Part Number:
    820-??????????????????
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      here you go
      i removed a password form your file (i hope)
      flash and test
      also you should be able to reset nvram (security)
      Resetting NVRAM
      Shut down your Mac.
      Locate the following keys on the keyboard: Command (⌘), Option, P, and R.
      Turn on your Mac.
      Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
      Hold these keys until the computer restarts and you hear the startup sound for a second time.
      Release the keys.
      test and report back
      also i think you will need to reinstall cos this clears efi password not os password but you will now be able to boot install cd or usb
      Im Back... sort of...
      • Mario
        • Sep 2007
        • 64
        Thank you. That file worked for me. I dont know board number. But its a i5 2011 board if that will help anyone else?
        • monkey1
          • Jan 2016
          • 10
          Hi I have a Question:
          I have a couple (Macbook Pro's, Air's and Retina's) all with (EFI firmware locks)
          I'm pretty good with component level repairs and programming etc... I generally use a
          (MiniPro TL866 Programmer) to program the EFI bios chips and I have a question in regards to editing a locked EFI Chip on the mac's
          After desoldering a Macbook Bios chip placing it in the (MiniPro) reading
          the chip then opening the Bin File with a Hex-Editor is there a way to delete the Serial Number from the file Bin file so that I could use that same Bin file on multiple MacBooks of the same model ?
          For instance when I ordered a EFI Bios chip from China all I had to do was solder it to the
          macbook book and i booted without having any (Serial Number) imbedded..
          If anyone could help it would be much appreciated
          Here is a Picture as to what section of the Bin i'm referring to:
          • seiiiif
            • Dec 2015
            • 11
            • sousse
            Need Help for A1466 Apple MacBook Air 13" i7 1.7G EMC 2632 MID 2013
            I need the original bin file for A1466 Apple MacBook Air 13" i7 1.7G EMC 2632 MID 2013 because when i tryed a bin file(for A1466 Apple MacBook Air 13" i5 1.3G EMC 2632 MID 2013) from my friend and it works but i have a problem with the trackpad and the keyboard they working in boot menu but not working after system start up
            Please Help Me thank you
            • highpulse
              i hate HP
              • May 2013
              • 1490
              • portugal
              seiiif reset nvram or reset SMC
              and you're up to go !
              • dhibubabu
                • 55
                • UAE
                Re: Need Help for A1466 Apple MacBook Air 13" i7 1.7G EMC 2632 MID 2013
                Hwllo Friend Same Problem Here , Did You get the bios ? can you share it please
                • boodledog
                  • 7
                  Can this be done for me too?? EMC 2555, not sure of the part number.
                  • macabook
                    by macabook
                    🧩 Initial Issue
                    07-24-2025, 02:17 PM
                  • cr4zychriss
                    by cr4zychriss
                    • Rebrand: PC Specialist
                    11-14-2025, 04:04 PM
                  • pirati
                    by pirati
                    10-27-2025, 04:20 PM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                  • istvanszasz99
                    Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                    by istvanszasz99
                    Product Name: Razer Blade 15 (2022)
                    Product ID: RZ09-0421
                    Motherboard: CH580
                    BIOS Versions I work with: 2.02 & 2.06
                    Bios File Size: 32,768 KB
                    Dear Forum Readers!
                    I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                    I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                    The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                    !!! MY RAZER BLADE...
                    11-24-2025, 05:52 PM
