hp folio 9470m
  • mabearce1
    • Jan 2022
    • 11
    Re: hp folio 9470m
    Originally posted by hoaca388
    Did you try with RCUnlocked ?
    Thats what I was using RCUnlocker...found it on this forum in another thread somewhere.
    • hoaca388
      Badcaps
      • Jan 2022
      • 11713
      #82
      Re: hp folio 9470m
      Why you do not post your dump bios file here. Someone else will help you ?
      • mabearce1
        • Jan 2022
        • 11
        Re: hp folio 9470m
        Here is my orig DUMP
        • Vesko356
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          #84
          Re: hp folio 9470m
          Don't you notice all the dumps in the topic are around and over 5MB in archived form, yours is only 1.73MB? This can be seen at first glance without even downloading and opening the file you uploaded, and this clearly shows your dump is not OK.
          Become a Badcaps supporter
          Thanks to all supporters.
          • hoaca388
            Badcaps
            • Jan 2022
            • 11713
            #85
            Re: hp folio 9470m
            here is my orig dump
            Just like Vesko 356 said. Your dump has a problem.
            • mabearce1
              • Jan 2022
              • 11
              Re: hp folio 9470m
              The size of the BIN is 16MB. I had to .rar it to allow it to be uplaoded the website wouldn't let me upload the .bin file. So the file its 16.8MB in size according to my computer here.
              • mabearce1
                • Jan 2022
                • 11
                Re: hp folio 9470m
                Sorry, I have just started getting into this type of stuff, what does this all mean?
                So, if my Dump has a problem, how can I fix it? is there a way to load a stock file? or someone else file onto it?
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #88
                  Re: hp folio 9470m
                  OK, here is a file (I specifically downloaded yours and edited it) which is also 16MB but archived is only 19.4 KB, simply because it is full of FF. Now do you understand what I'm talking about?
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 11713
                    #89
                    Re: hp folio 9470m
                    This is result from Alihomee's file ( #74 )
                    Maybe your issue from your programmer.
                    • mabearce1
                      • Jan 2022
                      • 11
                      Re: hp folio 9470m
                      Which program do you use? I have AsProgrammer and NeoProgrammer.
                      • mabearce1
                        • Jan 2022
                        • 11
                        Re: hp folio 9470m
                        okay so extract that and write it. do I set the chip to the q25w128FV? or is this one something different?
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 11713
                          #92
                          Re: hp folio 9470m
                          I have a Sofei SP20P programmer. Winbond 25Q128FV chip is easy detect by a Raspbery Pi too. ( with CH341A programmer , maybe you should solder out your chip from mainboard before reading chip )
                          First , choosing your chip name manually.
                          • mabearce1
                            • Jan 2022
                            • 11
                            Re: hp folio 9470m
                            So I have manually picked that chip. and nothing. thing doesn't power on at all! I have tried to do lots. I can red the chip all day long. But I write it and it goes through just fine. but power button....NOTHING. (and yes it did work previous)
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11713
                              #94
                              Re: hp folio 9470m
                              what's model of your mainboard ?
                              • mabearce1
                                • Jan 2022
                                • 11
                                Re: hp folio 9470m
                                So I have looked at a bunch of the numbers and none of them are showing the MB model.
                                But im gonna have the i7 version. gonna be like the higher end of the board if that helps? Where can I find it?
                                • newbfixer
                                  • Jan 2022
                                  • 8
                                  • United Kingdom
                                  #96
                                  Re: hp folio 9470m
                                  Hello I recently had a corrupted bios on an HP Elitebook Folio 9470m
                                  Symptoms:
                                  No display
                                  Fan Full Speed
                                  Constant flashing caps lock
                                  It had a winbond bios. 25Q128FVSG 1327
                                  I re-flashed the bios using the CH314 programmer from ebay with the 8 pin clamp cable.
                                  I used Asprogrammer for windows 10.
                                  Finally i have attached the 16mb bios that finally worked for me.
                                  Newbfixer
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11713
                                    #97
                                    Re: hp folio 9470m
                                    Last edited by piernov; 02-04-2022, 04:46 AM. Reason: remove full quote of previous post
                                    • newbfixer
                                      • Jan 2022
                                      • 8
                                      • United Kingdom
                                      #98
                                      Re: hp folio 9470m
                                      Also...
                                      To identify the motherboard you will have to disassemble the laptop
                                      There is a great guide here.
                                      https://www.youtube.com/watch?v=2bRonuysxpc
                                      The model info you are looking for is located here.
                                      Good Luck
                                      Newbfixer
                                      • mabearce1
                                        • Jan 2022
                                        • 11
                                        Re: hp folio 9470m
                                        so newbfixer, I tried to use yours and it says its protected, and when I click on the unprotect nothing really happens.
                                        I also tried the file that someone attached under your post. that wrote just fine. still no power with power button plugged in with charger.
                                        think it is just toast?
                                        • newbfixer
                                          • Jan 2022
                                          • 8
                                          • United Kingdom
                                          #100
                                          Re: hp folio 9470m
                                          I think you have a shorted component.
                                            HP EliteBook Folio EliteBook Folio G1 Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 boardview and EliteBook Folio G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 06:34 AM
                                            HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 + USB-C Universal Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 + USB-C Universal Dock boardview and EliteBook Folio G1 + USB-C Universal Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                            09-06-2024, 06:30 AM
                                            09-06-2024, 05:30 AM
                                            HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook Specification for Upgrade or Repair
                                            This specification for the HP EliteBook Folio EliteBook Folio G1 Notebook PC (ENERGY STAR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook Folio G1 Notebook PC (ENERGY STAR) boardview and EliteBook Folio G1 Notebook PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
