Help, I need bios dump for samsung NP535U3C
  • bios
    • Nov 2014
    • 64
    • Philippines
    This unit comes to me with power but no display in screen, when I power it on the back-light lit but no display in screen. This is samsung NP535U3C-P02PH
    model: LOTUS-13CML rev: 1.1
    Thank You.
  • bios
    • Nov 2014
    • 64
    • Philippines
    Re: Help, I need bios dump for samsung NP535U3C
    up
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      backup old and try this
      Im Back... sort of...
      • bios
        • Nov 2014
        • 64
        • Philippines
        Thank you ala borbe.. I will try it.
        • notserforumlar
          • Oct 2016
          • 12
          • midilli
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • Kjell
            Samsung Series 9 - BIOS issue
            by Kjell
            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
            08-01-2025, 09:15 AM
          • haitham sharabati
            by haitham sharabati
            Hello engineers 😀,
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            💀 Problem:😅
            08-07-2025, 04:54 AM
