need bios file for this model
acer E5-511
Re: acer E5-511
Hi
here is the newest update 1.08 all could be found on acer web site
Bios& Ec new . Always upload original it make my job easier and it's needed
Techman1025Comment
Re: acer E5-511
i tried all but no luck.orignal file is attached. motherboard code is Z5WAL LA-B211P Rev:1.0Attached FilesComment
Re: acer E5-511
Hi
Then problem an't bios for sure...so let us know what's the problem ? Laptop just an't starting ? How many spi chips ? let me know if any usb keyboard or mouse lights up.....are you getting the RSMRST3.3V & S5 3.3V are all voltage present dcin alwon 3&5V
Techman1025Comment
Re: acer E5-511
Hi
Anything on external monitor? Also try and disconnect internal display cable see if you get video. Next see if you have the 3v and display connector if not check display switch or you might have gpu or nb to test heat chip to 100c if video starts to work replace chip
Techman1025Comment
Re: acer E5-511
i have this problem too, but i think the problem here si KBC9012 ic-chip this chip is programmable but i don t have a specific eeeprom for this ic.
So i think this is the problem in this acer.Comment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by DanfayHello, I have an Acer Aspire 3 A317-51G, with a QH128AHIG XMC chip.
Due to a problem when I turn off the computer, I tried to upgrade the bios through Windows (10), this is the only possibility to update in Acer. Unfortunately, something went wrong
. The laptop starts but I can't even access the Bios. I searched for a long time, without success, for the Bios version in .bin file
The last functional Bios version was: InsydeH20, Rev. 5.0, Version 1.09 .
So I updated to version 1.11, which apparently either went wrong or is not functional.
Does anyone...
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
