i got this laptop that sometimes works but screen goes black after hp logo, and then starts blinking twice.
pavilion dv7 Bios needed plz....
Re: pavilion dv7 Bios needed plz....
here is your file, serial and model needs to be fixed with "hp nbdmifit" or post your dump and ill do it manuallyAttached FilesIm Back... sort of...Comment
Can i use the bios you posted AS IS? will it work?Comment
ok heres my old biosAttached FilesComment
here you goAttached FilesIm Back... sort of...Comment
I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
Symptoms:- Laptop powers on but no display at all (completely black screen)
- Caps Lock blinks twice with a pause, then repeats continuously
- F12 LED stays on permanently
- No POST, no boot sequence, nothing on screen
Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
What I've tried:- Hardware reset (battery removal, power
Channel: BIOS Requests ONLY!
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
by bhachiDear All,
following is the details
_______________
Laptop Model:-
HP Pavilion Gaming - 15-ec0026ax
Serial Number:-
5CD0038WRN
part number:-
8UZ38PA#ACJ
Old Bios Attached (2)Read_original.zip ( board starts but black screen )
I've attached one another bios file (1)NEW - Copy.zip ( downloaded from other source ) in that bios I got the screen ( see the attached picture ) ... and it restarts automatically and again no display
Thanks in Advance...-
by lagouzasHello, Laptop froze and got stuck in a prepost situation. It cannot be updated through a USB flash although it gets the signal to try to update bios through USB.
I ve read the Original Bios and I post it here. Bios chip seems ok.
I also post the screen opening if anyone has seen something like that.
There is a thread about Pavilion 15-EC20XXXX but with different mobo and Ryzen 5th instead of Ryzen 4th, I dont think I should try on this....-
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
- Loading...
