Hp 255 G1 bios dump need
  • zonzolo
    • Apr 2015
    • 13
    • italy
    Hello i need a dump bios of Hp 255 G1 laptop with amd cpu, the main board is 6050a2498701 mb-a02 TPN-I106.
    thanks in advance
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Hp 255 G1 bios dump need
    backup old bios
    two boards in this modes so two bios
    you will need to fix serial
    Im Back... sort of...
    • dilip.pawar31
      • Nov 2014
      • 59
      • india
      Thanks.......... Thank you
      • djamel1986
        • Jan 2015
        • 10
        • algerie
        Thank you
        • Levi
          • May 2014
          • 59
          • Ghana
          thnk you
          • DICA7510
            • Nov 2015
            • URUGUAY
            many thanks!!!
            • canali
              • Oct 2014
              • 196
              • turkey
              thnk you
              • Derach
                • Jun 2017
                • 17
                • burkina faso
                • rajureyan
                  • Apr 2015
                  • india
                  thankyou.
                  • islammostafa.me19
                    • Jul 2017
                    • 39
                    • egypt
                    thankyouvrymatch
                    • islammostafa.me19
                      • Jul 2017
                      • 39
                      • egypt
                      thanks to you
                      • lenn
                        • Nov 2014
                        • zimbabwe
                        thanx a lot
                        • carlucci
                          • Aug 2012
                          • 50
                          • Moçambique
                          much obliged
                          • elfenne
                            • Mar 2016
                            • 46
                            • maroc
                            thank
                            • ravenmx
                              • May 2018
                              • 182
                              • puebla
                              thanks you ala_borde
                              • elecom
                                • Jun 2018
                                • 10
                                • Cuba
                                Thank you.
                                • sda
                                  • May 2015
                                  • 11
                                  • Greece
                                  Greatly appreciated
                                  • dj_karpets
                                    • Nov 2015
                                    • 9
                                    • Ukraine
                                    thank you!
                                    • Ahari
                                      by Ahari
                                      I...
                                      08-13-2025, 06:12 AM
                                    • mkdj
                                      by mkdj
                                      Dear all,
                                      10-19-2025, 04:41 AM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • haitham sharabati
                                      by haitham sharabati
                                      Hello engineers 😀,
                                      🔧 Device Info:
                                      - Model: HP 15-da2007ne
                                      - Product Number: 8XF55EA#ABV
                                      - Serial Number: CND0338P0D
                                      - CPU: Intel Celeron N4000
                                      💀 Problem:😅
                                      08-07-2025, 04:54 AM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
