HP Elitebook 8560p new bios problem.
  • hansie55
    • Dec 2013
    • 254
    • Netherlands
    Changed the bios chip for the pw and it looked ok.
    After a while installing windows 8.1 it looked slow in start en restart.
    I tried to flash the latest bios which I was not sure it succeeded, so I did it a second time.
    The recovery I did with Mazzif way to force update. USB stick and keep Windowskey and B key pressed and push the power button.
    Now the system stays in this modus and don't do anything than blinking caps lock and fan at high speed.
    Anybody can help how to get out of this?
  • Life Goes On
    • May 2014
    • 264
    • Curacao
    Re: HP Elitebook 8560p new bios problem.
    Flashing the bios s always a risk, i think something when wrong, you can try to reset the mobo, and see what it does.
    The Night Drop Down, I Will Keep Try Until..., You Never know.
    Dushi Kòrsou, Nos Tei.
    • hansie55
      • Dec 2013
      • 254
      • Netherlands
      Masha Danki pa reaction,
      How to reset the mobo? I had it without battery, RTC battery and adapter for a day and as soon the system starts, it jumps into the programming modus. ( same when you hit windowskey and B key, capslock wil blink)
      • dycc
        Vision
        • Nov 2011
        • 625
        • Côte d'Ivoire
        [QUOTE=hansie55;576571]Masha Danki pa reaction,
        How to reset the mobo? I had it without battery, RTC battery and adapter for a day and as soon the system starts, it jumps into the programming modus. ( same when you hit windowskey and B key, capslock wil blink)[/QUOT
        • hansie55
          • Dec 2013
          • 254
          • Netherlands
          Thanks Dycc, but what do I have to do? Combine the 2 files. (forgive my ignorance)and then...
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            flash bios with programmer
            • hansie55
              • Dec 2013
              • 254
              • Netherlands
              Sorry, I do not have a programmer. I replaced the bios chip again with a new one and it works OK. Only the ID's are missing, where he complains about during Post. Also when starting post, he shows a line stating "Manufacturing program mode set: 6 of 10". And he also does not restart. He closes the programs and blank the screen and than freezes. When you switch off by hand he shuts down.
              seems that I got a lot to figure out.
              Something I never seen before, is that system screen turns black after a few minutes and can't be retrieved other than a restart.
              When you take out the adapter the screen pops back up ???????????????
              Tried this with several adapters and it was the same. Installed all the available drivers for this system from HP site and the problem disappeared.
              • STKR123
                The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                by STKR123
                Greetings badcaps community,
                I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                I learned that desoldering...
                10-29-2024, 06:03 AM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • Guest
                Elitebook 850 G5 BIOS bricked
                by Guest
                I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                I assume the BIOS update failed, so I searched for the BIOS chip.
                I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                Can the corrupted...
                03-24-2025, 01:21 AM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
              • lap-top123
                Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                by lap-top123
                HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                Hp Elitebook 850 G8
                ProdID 52W98EC#ABD
                SN# 5CG1458XQ7
                Mac-address #1: 84:14:4D:2C:4B:5B
                UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                Mainboard : 6050A3216701-MB-A01(A1)
                08-20-2025, 07:28 AM
