cq56_102la need bios
  • banchi99
    • Jul 2015
    • 107
    • U.S.A
    Need bios or dump
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: cq56_102la need bios
    backup old bios and try this
    serial needs to be fixed with NBDmiFit
    od post old bios and ill do it for you
    Im Back... sort of...
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
