cq56_102la need bios
  • banchi99
    • Jul 2015
    • 107
    • U.S.A
    Need bios or dump
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: cq56_102la need bios
    backup old bios and try this
    serial needs to be fixed with NBDmiFit
    od post old bios and ill do it for you
    Im Back... sort of...
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
      by haitham sharabati
      Hello engineers šŸ˜€,
      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
      šŸ”§ Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
      šŸ’€ Problem:šŸ˜…
      - Device shows ā€œAdministrator Passwordā€...
      08-07-2025, 04:54 AM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
    • DynaxSC
      by DynaxSC
      11-17-2023, 10:56 AM
    • greelidd
      K6604J Vivobook RTX 4070 BIOS Dump Request
      by greelidd
      Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
      Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
      09-01-2025, 06:14 PM
