HP 15 bios dump need!!! (LA-A994P)
  • bios77
    • Feb 2015
    • 4
    • yalova
    Hp 250 g3 (la-a994p ) bios please
  • maestro_lpc
    • Mar 2015
    • 14
    • Georgia
    Re: Hp 250 g3 bios dump
    What BID you want? There are 4 bios dump 8mb.
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      Hi guys good day.. please help me.. i need bios dump for my hp laptop.
      here is the board model: LA-A994P REV: 2.0
      thanks guys
      • dspok
        • Jan 2014
        • 553
        • Nepal
        Re: HP 15 bios dump need!!! (LA-A994P)
        one of the attached bios will work.
        save your old bios & try.
        • rachid34000
          • Jan 2015
          • algeria
          think you
          • minhaj
            • Jul 2015
            • 13
            • india
            thanks you
            • jatoi
              • Jan 2015
              • 82
              • pakistan
              thanks
              • makina1982
                • Sep 2014
                • 4
                • Chile
                plase i need dump zs040 la-a995p
                thank a lot!
                • angel-boy
                  • 550
                  • Romania
                  try this one....
                  • Lex-
                    • May 2011
                    • 18
                    Please help, I need EC (KB9012) dump ZSO40 LA-A995P or a way to extract it from the hp BIOS update. Thanks.
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      no EC update from web update
                      this laptop has 4 versions of the boards, here is 4 bioses
                      Im Back... sort of...
                      • Lex-
                        • May 2011
                        • 18
                        Thank you ala_borbe, my board version is 0220F, flashed it with the file provided by you, but still no image on display, I think that maybe EC firmware corrupted because the board uses KB9012 and becomes corrupted frequently, I have the programmer for EC, only need the correct dump to flash it, any advice please ?
                        • ala_borbe
                          aka Donald
                          • 1625
                          • Malta
                          well try this
                          found on some site, not my work
                          it also may not be bios or ec problem, many other things may cause similar symptoms
                          bios f18 + ec
                          • ridamouh159
                            • Nov 2014
                            • 365
                            • maroc
                            This is for hp250 g3 core i3
                            • makina1982
                              • Sep 2014
                              • 4
                              • Chile
                              thanks angel-boy but dont work :-(
                              • alas3376
                                • Nov 2011
                                • 382
                                • BENIN
                                thanks
                                • MetalSerj
                                  • Dec 2015
                                  • 3
                                  • Moldova Republic of
                                  thanks friend!!!
                                  • ibrahim_yas
                                    Banned
                                    • Nov 2015
                                    • 20
                                    • 86159159666
                                    thanks u very much admin
                                    • ibrahim_yas
                                      Banned
                                      • Nov 2015
                                      • 20
                                      • 86159159666
                                      again thanks you..
                                      • sandaruwan
                                        • 19
                                        • Sri Lanka
                                        thanks
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          Yesterday, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
                                        • grimacelord
                                          Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                                          by grimacelord
                                          This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                                          Motherboard model number: DA0PAMB46A1 REV: A
                                          Secondary motherboard model number: 0PAB
                                          SKU: 685K4UA
                                          Serial number is: 5CD3223BJP
                                          Recently reflashed this laptop with latest BIOS and once...
                                          05-07-2024, 08:06 AM
