HP 15 bios dump need!!! (LA-A994P)
  • andrzej1122
    • Jul 2018
    • 10
    • Polska
    #121
    Re: HP 15 bios dump need!!! (LA-A994P)
    Need bios model Compaq 15-s035nb, ZS050 LA-A994P REV 2.0 2014-03-13, ENE KB9012QF A4 (U44), greetings
    • peste
      • Dec 2016
      • 12786
      • ROMANIA
      #122
      post the original bios of the laptop
      • andrzej1122
        • Jul 2018
        • 10
        • Polska
        #123
        oryginalny bios
        • peste
          • Dec 2016
          • 12786
          • ROMANIA
          #124
          oryginalny bios
          bios extracted from the HP site update, the laptop has four bios variants, yours is 0220F
          DMI + KEYWIN 3780000 - 38203F
          • andrzej1122
            • Jul 2018
            • 10
            • Polska
            #125
            thank you for your time, the processor is most likely damaged, best regards
            • jorge41403
              • Mar 2023
              • Cuba
              #126
              Originally posted by dspok
              one of the attached bios will work.
              save your old bios & try.
              Hp 250 g3 ???
              • kameldw
                • Mar 2023
                • 10
                • algerie
                #127
                thanksss
                • Kabbor
                  • Jun 2024
                  • morocco
                  #128
                  i have probleme in ezp2019 (failed check error 10h) help me
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • MDSI
                    HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                    by MDSI
                    I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                    Details:
                    Model : HP OMEN 17-an012nf
                    Motherboard Part Number : DAG3BAMBAF0 REV : F
                    Serial Number (S/N) : 5CD7280D51
                    BIOS chip : Winbond W25Q64VSIQ
                    Programmer : EZP2023+
                    Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                    I already...
                    07-28-2025, 07:11 AM
                  • grimacelord
                    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                    by grimacelord
                    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                    Motherboard model number: DA0PAMB46A1 REV: A
                    Secondary motherboard model number: 0PAB
                    SKU: 685K4UA
                    Serial number is: 5CD3223BJP
                    Recently reflashed this laptop with latest BIOS and once...
                    05-07-2024, 08:06 AM
                  • DynaxSC
                    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                    by DynaxSC
                    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                    11-06-2022, 05:22 PM
