HP 6735s dead after bios upgrade
  • DS-1
    • Jun 2015
    • 82
    • Italy
    Hi guys!
    I have this 6735s that I upgraded from Vista to 7. I had the problem that I can't regulate brightness in Windows 7. Searching in the net, I've found that the problem was the outdated bios. I downloaded the last 2.1 bios release of this bios and did the upgrade thru FreeDOS (using ROMpaq.exe). The operation went to the end without problems.
    Maybe I did the mistake to reboot the PC with ctrl alt del and not shutting it down from the button. The PC restarted with black screen. After a couple of minutes, I shutted it down from the button and tried to turn it on again. From that moment, I only obtain AC adapter orange light blinking (with blue always on), while I only put the jack in and nothing more happens. No button or light works.
    Now I believe I have a BIOS corrupted in my PC. How can I try to reprogram it?
    Thanks in advance for the reply.
  • dspok
    • Jan 2014
    • 553
    • Nepal
    Re: HP 6735s dead after bios upgrade
    yes, BIOS is corrupt.
    someone is able to recover corrupt BIOS using BIOS Crisis Recovery using USB. See below link.
    http://www.systutorials.com/3022/hp-...bios-flashing/
    or you can use EEPROM Programmer and flash attached BIOS file.
    • DS-1
      • Jun 2015
      • 82
      • Italy
      Thanks for the reply, dspok!
      Unfortunately I can't use Crisis Recovery mode, because my 6735s won't boot at all. When I press the power button, nothing happens!
      Should I desolder the BIOS to re-program it? Can you tell me what programmer should I buy for this operation? Is there any diy programmer to assemble?
      What BIOS chip 6735s has?
      • dspok
        • Jan 2014
        • 553
        • Nepal
        @DS-1
        you can use any universal EEPROM Programmer but for this job done I use Top2011.
        see on ebay.
        http://www.ebay.com/bhp/eprom-programmer
        • DS-1
          • Jun 2015
          • 82
          • Italy
          I'm from Italy, so I'm checking into the italian eBay page.
          Is something like this good for this job?
          http://www.ebay.it/itm/CH341A-24-25-...item51bc3fde34
          • dspok
            • Jan 2014
            • 553
            • Nepal
            It may work but I'm not sure.
            • DS-1
              • Jun 2015
              • 82
              • Italy
              Do you know what BIOS chip 6735s has? I will look for a programmer that can be used for that kind of chip.
              • dspok
                • Jan 2014
                • 553
                • Nepal
                as per schematic 6735s have SST25VF016B chip.
                is your laptop AMD version?
                • DS-1
                  • Jun 2015
                  • 82
                  • Italy
                  Yes, my 6735s has Sempron AMD processor and ATI 3200HD graphic card.
                  • DS-1
                    • Jun 2015
                    • 82
                    • Italy
                    I've found this, too. It's from China. Is it that hard to desolder the BIOS from the motherboard?
                    http://www.ebay.it/itm/EZP2010-High-...item2eb96ace7a
                    • sopik78
                      • Nov 2013
                      • 518
                      • Czech Republic
                      The EZP2010 is sufficient. I recommend to buy a set of socket adapters for easy change SPI chips.
                      The best way to desolder the chip is to use a hot air gun.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3622
                        • slovakia
                        or u can buuy clip to program on board
                        • dj_ricoh
                          • 2073
                          It does not work.
                          I try and almost fry my usb where the programmer was.
                          He try to power the board trough usb lol.
                          Desolder read write solder it back and thats it.
                          I got clip because i dont wanna solder on adapter. So yee
                          I was thinking to try to read with notebook.on via a usb hub with psu.
                          • DS-1
                            • Jun 2015
                            • 82
                            • Italy
                            http://www.ebay.it/itm/291300736180?...%3AMEBIDX%3AIT
                            Can this work for what I need? It is cheaper.
                            Both programmers I've linked seems to have adapter to be used with SST25VF016B.
                            • Loli Popu
                              DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                              by Loli Popu
                              Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                              12-13-2024, 03:28 AM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • tranquility
                              Asus X515KA not booting. after flashing bios sometimes i come there. but then dead again
                              by tranquility
                              hallo,
                              i have an asus X515KA-EJ058W here.
                              just both leds white...he battery blinking without battery connected
                              consuming ~400mA and tries to start but nothing happens but fan spinning if cpu gets warm
                              if i hold the power button it shuts down and consumes ~30mA i cant spot anything getting warm with thermal....the ec/sio a liiiitle but this is maybe normal beacause it is working ?
                              power on again is possible but again 400mA then and no picture.
                              now the really strange
                              i flashed bios (some version i found on the internet) and resoldered....sometimes...
                              12-11-2024, 06:47 AM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
