HP 15 DAR62CMB6A0 Bios file needed
    The mentioned notebook had a no display problem. Power Switch voltage ok and bios supply also ok..
    Thanks...
    Re: HP 15 DAR62CMB6A0 Bios file
    try this one i think this file are working
      Re: HP 15 DAR62CMB6A0 Bios file needed
      No. Its not working.
        Sorry. It's working perfect. Thank you.
            thanks
              try this
                thanks.. but it shows Flashing Boot Block 79% ;/
                  hello hp 15-r007tx bios file av?
                    Originally posted by pcnetch View Post
                    try this
                    Thank u
                      thanks
                        Thank you.
                          thank you good work
                            HP 15 DAR62CMB6A0 power led blinking,some time power is ok solution pls..........
                              Thank you dilip.pawar31
                                Nice, it works.
                                  please i have HP dar62cmb6a0 rev:a with no display problem.
                                  flashing the two bios chip as proven futile only the one at the SIO chip is detected by my programmer but the other no. please can you help .
                                    Thank you itworks
                                      thank you
                                        Thanks..
