need bios dump for ASUS Z53J
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    someone can help me, I need bios dump for ASUS Z53J
    thanks in advance
  • Ramee
    • Jul 2014
    • 218
    • Israel
    Re: need bios dump for ASUS Z53J
    Try this one, it might work
    • ridamouh159
      • Nov 2014
      • 365
      • maroc
      many thanks young .
      i will try it
      • ridamouh159
        • Nov 2014
        • 365
        • maroc
        your file is 1mb but the realy bios is 512kb
        the bios is sst25vf040
        • Ramee
          • Jul 2014
          • 218
          • Israel
          May be you have two bios, look for another one.
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Anchar777
            ASUS P1412CE need BIOS DUMP
            by Anchar777
            Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
            06-26-2025, 03:39 AM
          • shadow666
            ASUS Vivobook M3500QA Dump Bios
            by shadow666
            Hi
            i need dump bios for
            Motherboard : M3500QA
            Rev : 2.1
            CPU : AMD Ryzen 7 5800H
            GPU : NVIDIA GeForce RTX 3050
            i tested any bios in this topic but don,t working , I think the files placed in this thread are for the uma motherboard
            Code:
            https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/bios-requests-only/95276-dump-asus-vivobook-pro-15
            i,m attached backup bios & problem is notebook power on but don,t boot and blank screen
            Regards...
            01-10-2024, 10:41 AM
          • robgerr
            Asus K3500P Main (X7400PC R2.2) Bios Dump Reques
            by robgerr
            Good morning forum, I'm trying different bios to try to resurrect this machine, with all the bios tried the machine turns on, the fans turn but the screen is black. I tried to download the correct bios from the Asus website (x3500PC by reading the QRCODE from the motherboard) but this is a PFAT AMI, I managed to decrypt it but I get several files and rebuilding it is very laborious, I tried with the uefi tool to extract only the main bios and cut the decrypted one and rebuild it in hex but it doesn't work the same. Wondering if anyone has a dump for this main board. I thank you.
            Attach...
            11-17-2023, 09:52 AM
