Help, need bios dump for MSIU123X
  • bios
    • Nov 2014
    • 64
    • Philippines
    Hello guys.
    Can anyone help me, I need bios dump for MSI U123X model: MS-N033
    MS-N0331 VER: 1.0 I got no power on this netbook, no response while pressing the power button but I got 3.3v and 5volts. Here is the old bios.
    Thank you..
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Help, need bios dump for MSIU123X
    try this
    Im Back... sort of...
    • bios
      • Nov 2014
      • 64
      • Philippines
      Thank you ala borbe I will try it.
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
      • Citymin
        by Citymin
        S/N : 5RNK9FFT70...
        08-05-2025, 05:12 AM
