Acer E1-531 bios dump
  • Mazorca
    • Jan 2017
    • 463
    Re: Acer E1-531 bios dump
    Get yourself a cheap programmer, read it at least three times and compare them all until all are identical, this is your backup, then flash with file from #7, and read flashed chip, compare it again to verify. Disconnect CMOS bat, main bat too. Read more here in forum, lots of info on main BIOS Request page. If having trouble, ask again.
    • Nynd
      • Aug 2022
      Thanks for the info.
      • James194zt
        Acer Nitro 50-640E Corrupted BIOS Dump
        by James194zt
        My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
        All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...
        04-28-2025, 03:29 PM
      • Ahari
        by Ahari
        I...
        08-13-2025, 06:12 AM
      • mkdj
        by mkdj
        Dear all,
        10-19-2025, 04:41 AM
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • x14nl34l
        Acer TravelMate p614 (tmp614-51-g2-5442) bios dump
        by x14nl34l
        Hi, I need a bios dump for my Acer TMP614 (tmp614-51-g2-5442 bios dump). Thanks.
        09-01-2025, 09:54 PM
