U93 Bios Dump
  • pcnetch
    • Aug 2013
    • 125
    • Sri Lanka
    U93 Bios Dump
    Hi... if any one wants HP u93 bios here.....
  • angel-boy
    • 550
    Re: U93 Bios Dump
    tks for sharing.
    • alas3376
      • Nov 2011
      • 382
      • BENIN
      Re: U93 Bios Dump
      thnx for sharing
      • 580shahzad
        • Jan 2012
        • 65
        • PAKISTAN
        Re: U93 Bios Dump
        thanx
        • cristiannec
          • Oct 2014
          • 51
          • Italia
          Re: U93 Bios Dump
          thanx!
          • Sebas3124
            • Mar 2014
            • 15
            • Colombia
            Re: U93 Bios Dump
            i tested this bios and this not worked, but i found a old board with good bios, good lock
            • mainah njoroge
              • Aug 2017
              • 38
              • kenya
              Re: U93 Bios Dump
              thank you
              • MiguelRico981228
                • May 2020
                • 38
                • Colombia
                Re: U93 Bios Dump
                Thankss, working for me
                • Ahari
                  by Ahari
                  I...
                  08-13-2025, 06:12 AM
                • mkdj
                  by mkdj
                  Dear all,
                  10-19-2025, 04:41 AM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  by haitham sharabati
                  Hello engineers 😀,
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  💀 Problem:😅
                  08-07-2025, 04:54 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
