hp 17-e189nr bios
  • dj_ricoh
    • 2073
    hp 17-e189nr bios
    hello dear working technicians
    can some one help me with a dump file for notebook?
    thank you
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp 17-e189nr
    of all people i would expect from you to post old dump or motherboard number
    anyways, backup old bios and try this, no serial, extracted from web update
    two different veriosn inside BID01982 and BID02139
    hope it helps
    Im Back... sort of...
    • dj_ricoh
      • 2073
      Re: hp 17-e189nr
      Hahahaha i was writing to you exacly the same you said. Omfg
      And the comp did a restart and deleted 2 min of writing .
      lazy after work soo abandon and wrote from phone.
      Nvm something happen with the chip after i read it starting to give error on verify.
      Thats why i wanted to write you.
      Got the old file but tonight cuz only tomorrow i will work on that sh itty hp.
      I will attach the file with it and everything.
      Thank you
      P.s. This is foe SEO HP BIOS NO POWER NO JACK LIGHT
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        Re: hp 17-e189nr
        ok, it was a joke anyway but we think alike
        if eeprom erases, writes but cannot verify its most likely faulty so its best to replace it
        you wrote that no light on power jack... that may be hardware fault but may also be the EC or EC bios... if board has second eeprom dump it as well
        if your power brick (adapter) has 3 pins, be sure to try with another known working one, sometimes middle pin get loose and it can do strange symptoms...
        • dj_ricoh
          • 2073
          Re: hp 17-e189nr
          this is the original bios!
          after i copy i try to verify and start to give me error.
          after a full erase i program it back and notebook came to life but no display.
          this is why is suspect the bios may be culprit.
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            Re: hp 17-e189nr
            i can confirm that your dump is not working, but i have managed to determine bios for you
            and i fixed dmi data for you
            take attached file, erase eprom, write this file and verify... it must verify, otherwise change eeprom IC
            off topic
            badcaps is runnung slow for me, it takes me 5 min to download 2-3mb
            sometimes i cant open forum at all
            • dj_ricoh
              • 2073
              Re: hp 17-e189nr
              for me its with hp website when i go to storage room!
              omg! i hate BT
              p.s. TY
                • 30990
                Re: hp 17-e189nr
                BT and friends lost a lot of fibre the other day in a tunnel fire.
                nobody really knows the truth about what happened because the area has a lot of semi-secret government and private tunnels in close proximity to each other.
                • dj_ricoh
                  • 2073
                  Re: hp 17-e189nr
                  Perfect!
                  It sais manufacturer programming mode unlock.
                  Nvm it works im happy.
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    Re: hp 17-e189nr
                    im glad to hear that
                    if you enter bios and there is no serial num or model num the fix it with nbdmifit
                    (it should be, i copied that data from your dump)
                    that data can be found on bottom of the laptop or when battery is taken out
                    • italiasimo
                      • Sep 2014
                      • 13
                      • morroco
                      Re: hp 17-e189nr
                      Tinks
                      • iZakre
                        HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                        by iZakre
                        Hello everybody!
                        To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                        The thing is that I had installed TeamViewer and could log into the computer...
                        02-19-2023, 02:27 PM
                      • bondminer009
                        Need Bios for Latitude 7650 (No Original / dump bios file)
                        by bondminer009
                        Good Evening,
                        Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                        Thank You
                        Salam,
                        Three
                        11-12-2024, 07:48 AM
                      • joshAU
                        BIOS file for N550JK (original dump attached)
                        by joshAU
                        Hi all.
                        I'm looking for a BIOS file for an Asus N550JK.
                        I have a Asus R552J, which I believe is identical to the Asus N550JK.
                        I downloaded the latest BIOS (210) for the R552.
                        It is named N550JKAS.210.
                        The BIOS file is however only 6mb in size.
                        I've read the chip with a CH341A programmer and verified the file.
                        That file is actually 8mb in size.
                        I'm wanting to remove the BIOS password from this unit.
                        It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                        08-09-2022, 08:06 PM
                      • adelage
                        Merge ECS Z77-H2 bios cap file with original dump
                        by adelage
                        I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                        03-11-2025, 03:07 AM
                      • silverflea
                        Need Bios MSI B75A G43 Dump File
                        by silverflea
                        Hi. I need dump file bios MSI B75A-G43
                        My bios got corrupted and wont boot, so i need to flash it using Ch341A programmer, but bios file from the official website is to large, so i need bios dump file from working motherboard, or anyone know how to cut the bios size to fit bios chip
                        Thanks!
                        08-09-2022, 01:37 AM
