hcl me icon L 1015 bios plz
Re: Hcl laptop
backup old bios and try this
when bios is updated from dos, it uses some RSA key for something so writing this to eeprom may not work
in that case dump your bios i will try to fix it or try to find working dumpAttached Filesif you find these attachements useful please consider making a small donation to the site
Im Back... sort of...
Re: Hcl laptop
Try it
if error or size mismatch upload your old backupAttached Filesif you find these attachements useful please consider making a small donation to the site
by AhariHi all,
I...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
