Ibm lenovo r60 bios locked
  • xalien
    • Feb 2015
    • 65
    • thessaloniki
    Hi
    I have this problem with my IBM LENOVO R60 it is start up and i see the logo and after in my screen i see locked and wait for passwd .What can i do ?
    thanky
  • mesersmith
    • Dec 2014
    • 35
    • România
    Re: Ibm lenovo r60 bios locked
    I didn't try to erase boios password on Lenovo, but I did often to other names.
    Try to remove bios battery and short the battery socket pins for 10 seconds.
    This metod works to Acer, Asus and other.
    • xalien
      • Feb 2015
      • 65
      • thessaloniki
      I have do all this my friend i taken off my battery from my laptop nothing. This is a supervisior passwd i dont now this procedure to reset it . Any body to help me ?
      thanky
      • Esse
        • Apr 2014
        • 317
        • TOGO
        I have this on ACER TRAVELMATE 220 SERIES But it did not work.help please
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          How's your soldering
          http://sodoityourself.com/hacking-ib...bios-password/
            • 30941
            of course it didnt work, that method is for motherboards, not laptops.
            you need to either calculate a master password from the bios serial number, or use a service manual to locate a bypass point on the board.
            • Wahaz
              by Wahaz
              10-30-2023, 08:42 PM
            • grimacelord
              by grimacelord
              Hello there.
              History:
              03-15-2023, 03:29 PM
            • jendkkd jeje
              Lenovo IdeaPad 330 15-AST 81D6 BIOS Recovery
              by jendkkd jeje
              So a couple of years ago i got a bios update through Lenovo Vantage, so i installed it and bricked my whole BIOS, so i couldn't fix it so i put that ideapad in a box, 3 years later i found that one PC and want to recover it to switch from a 2014 hp laptop to this one.
              I found a method to recover the BIOS of many lenovo laptops tha consists in pluging in a USB Flash with the BIOS files and power on the laptop with Fn + R keys pressed until fans go loud and start beeping loud, but nothing worked, so i think filename is wrong, i tried naming the bios file as 07WW.BIN, BIOS.BIN, BIOS.fd,...
              10-11-2024, 03:12 PM
            • opensourcefan
              Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS
              by opensourcefan
              Hey all, I have a Lenovo X1 Yoga 1st Gen (model - 20FQ) with a locked BIOS. I would like to unlock it.
              Currently I have it apart in all its glorious bits looking for the security eeprom that I can't find. Plan was to jump it. Next step I think is to pull the BIOS IC and flash a decryption file to it?? I'm a bit confused on that process.
              1. Pull the BIOS IC,
              2. Read and save the original locked file
              3. Flash the decryption file
              4. Install and boot up and remove password from BIOS
              5. Remove BIOS IC again
              6. Flash Original locked...
              11-19-2022, 06:18 PM
            • mximiliandz
              help bios lenovo ideapad s145-14iil type 81w6
              by mximiliandz
              Good morning, gentlemen, I hope you can help me with my laptop, I told you that I saved it about 2 years ago because it wouldn't turn on, now I have a ch341a programmer, I made a backup of the bios, I flashed an original downloaded from lenovo and it started, but it turned off after a few minutes, I entered the bios configuration and the brand, model, serial number, windows serial number, etc. did not appear, I request your help, I did everything I found in the forum but I could not solve it, also now it won't start again, it turns on but the fan does not turn, I will share all the information...
              06-20-2025, 06:50 AM
