need bios for HP Probook 4441s
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    i need bios for HP Probook 4441s.
    please share.
    thanks.
  • JeffJ
    • Apr 2012
    • 189
    Re: need bios for HP Probook 4441s
    Just download it from HP. They offer full bios files in their flasher. And actually have a bad flash recovery processes built into their Probook and Elitebook series. No need to even open these units if you have a bad bios flash.
    Make a Fat32 partition of 2GB on a USB stick called HP_TOOLS. place bios in there for your model according to their recovery instruction. Boot the unit holding the recovery keys, and you're back in business.
    Reference for you http://support.hp.com/us-en/document/c02693833
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      or post your old bios dump here and i will help you
      Im Back... sort of...
      • JeffJ
        • Apr 2012
        • 189
        The probooks and elitebooks will not flash a bios with out a Sig file that matches the binary. so a dump obviously wont have a sig.
        I've tried flashing a dump back to my Elitebook, and it always rejects it. Force flashed it to the SPi chip and it refused to boot. Had to recover the bios. HP's bios are encrypted and are signed via RSA. This is the same reason why no one to this date has removed the white-lists from these bioses as far as i have found.
        "That .sig file is unique and will not verify any other roms expect the one it was made for. So any modifications to the bios will require a new .sig in order to flash it via efi. Unfortunately we can only generate the .sig when the bios is previously encrypted by HP or if we know HP's private RSA key."
        If you have a corrupted bios the way to recover it is with the suggestion i made earlier. If your trying to modify it, the machine will refuse to boot on it and will need the bios recovered, if you force flash it. If you use HP's built in recovery to flash it or their flash tool it will just tell you its invalid.
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          @JeffJ
          you are wrong for some aspect
          @masud
          backup old bios and try both
          first file dump from some laptop, not mine dump
          second file some of my work
          pls try both
          • mjalil28
            Banned
            • Oct 2015
            • 45
            ala_Borbe Thnk's Man
            • Pascal Komlassan
              • Jan 2017
              • 808
              • TOGO
              good bro....
              • meomeo13
                • Aug 2017
                • 9
                • thailand
                thanks you.
                • talat
                  • Oct 2017
                  • 15
                  • pl
                  thanks
                  • natnaphat
                    • Sep 2018
                    • 13
                    • Thailand
                    thanks
                    • comfe
                      • May 2016
                      • 6
                      • Turkey
                      thnx
                      • fyaagoub
                        • 269
                        • maroc
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          It freeze at HP logo.
                          • raajkumar
                            • Mar 2015
                            • 354
                            • Srilanka
                            @JeffJ
                            @masud
                            pls try both
                            Is it working for Discrete motherboard ?. I upload it. its working showing logo only there is no vcc_gfxcore and gfx coil also not giving power. and its freezes on that logo stage. no response on keyboard or usb. There is no old bios chip on this motherboard. someone has removed it already.
                            • studdy05
                              Bricked HP Probook 450 G7 Bios questions
                              by studdy05
                              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                              Ive got...
                              07-08-2025, 09:24 PM
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • sssssssssssssss
                              Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                              by sssssssssssssss
                              I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                              Symptoms:
                              • Laptop powers on but no display at all (completely black screen)
                              • Caps Lock blinks twice with a pause, then repeats continuously
                              • F12 LED stays on permanently
                              • No POST, no boot sequence, nothing on screen
                              Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                              What I've tried:
                              • Hardware reset (battery removal, power
                              09-04-2025, 06:45 AM
                            • pirati
                              by pirati
                              10-27-2025, 04:20 PM
                            • The_Memory_Guy
                              Dell T7820 stuck in Bios Recovery Mode
                              by The_Memory_Guy
                              HI,
                              I have a Dell T7820 stuck in Bios recovery mode. I never get Dell Boot screen or anything visible on screen. The system just gives me 3 white lights and 3 orange lights indicating Bios recovery mode.
                              What I have tried to get to recover the Bios, there seems to be some conflicting advice about recovering the system.
                              All of them say to download the latest bios from the dell website which is a .exe file. I have done that
                              https://www.dell.com/support/product...BUT090/drivers
                              Some...
                              07-07-2025, 06:52 AM
