MS-N0141 ver-2.1
msi mini MS-N014 bios needed
Tags: None
Re: msi mini MS-N014 bios needed
Whats it for the U130 ? or the MSI Wind U135 DX..
Check there site make sure you download and flash it with the correct one
for your chip
This is for the 'MSI Wind U135 DX'
http://www.msi.com/support/nb/U135DX.html#down-biosLast edited by calos2015; 03-01-2015, 06:28 PM.Comment
Try it....Attached FilesComment
Re: msi mini MS-N014 Help Not Working
Hi all.
I have a Laptop with the motherboard model MS-N0141 V.21.
The flaw is that it does not give video.
When connecting the charger, sometimes it does not do anything, other times it turns on, but a buzz is heard.
You connect a pendrive and when you do the ignition process, you can see the flash pendriver light.
The failure occurs with the RAM module installed, as if it does not have it, (internal RAM on board)
The rest does not do anything else, connect a USB keyboard and do not turn on the lights of it.
I did the test to connect the battery and the red LED flashes. (Loading process)
Previously, check the voltages and the voltages of 3.3v, 5v, 19v, 1.0, 1.5, 0.70vdc are correct.
With the oscilloscope, there is signal activity in the BIOS terminals.
I did not find any pulse activity on the keyboard connector, I think there should be some signal on those pins. Near the chip. "ENE" However in some pins I found pulse trains.
Can you help me in what may be the problem with that plate?
Thank you
Español / Lenguage Natal.
Hola a todos.
Tengo una Laptop con la tarjeta madre modelo MS-N0141 V.21.
La falla es que no da video.
Al conectar el cargador, a veces no hace nada, otras veces enciende, pero se escucha un zumbido.
Le conecte un pendrive y cuando hace el proceso de encendido, se observa la luz del pendriver destellar.
La falla se produce con el módulo de memoria RAM instalado, como si no lo tiene, (RAM interna en placa)
Del resto no hace más nada, conecte un teclado USB y no se encienden las luces del mismo.
Hice la prueba de conectar la batería y se enciende el led rojo destellando. (Proceso de carga)
Previamente, verifique los voltajes y están correctos los voltajes de 3.3v, 5v, 19v, 1,0, 1,5, 0,70vdc.
Con el osciloscopio, hay actividad de señal en los terminales del BIOS.
No encontré ninguna actividad de pulsos en el conector de teclado, pienso que debería haber alguna señal en esos pines. Cerca del chip. “ENE” Sin embargo en algunos pines encontré trenes de pulsos.
¿Pueden ayudarme en que puede ser el problema de dicha placa?
GraciasComment
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
>Read BIOS guides, methods, resources and tools
Ack
>Try the method at BIOS guides, methods, resources and tools before requesting help
Ack
>Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
Channel: BIOS Requests ONLY!
by dg01HP Elite mini 800 G9 corrupted bios, can any one provide a working bios or provide details how to rebuild the corrupted bios to a working one. Thanks in advance for any help provided
Serial Number: 8CC3252CMF
by macabookHello everyone,
07-24-2025, 02:17 PM -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by piratiHello everyone,
- Loading...
