asus k42f 3.0
  • alihomee
    • Dec 2012
    • 1577
    • malaysia
    asus k42f 3.0
    need bios file for this urgeng ....please
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: asus k42f 3.0
    read and post your dump here
    Im Back... sort of...
    • innocentforeign
      innocentforeign
      • Jun 2013
      • 172
      • KSA
      Re: asus k42f 3.0
      need bios for asus k42f
      old bios is attached
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        Re: asus k42f 3.0
        try
        • innocentforeign
          innocentforeign
          • Jun 2013
          • 172
          • KSA
          Re: asus k42f 3.0
          thanx a lot ala_borbe
          i have already tried its 2mb and old bios is 4mb
          • innocentforeign
            innocentforeign
            • Jun 2013
            • 172
            • KSA
            Re: asus k42f 3.0
            please share if any one have same bios
            • atsio
              • Oct 2013
              • 819
              • Greece
              Re: asus k42f 3.0
              Try this
              • hansie55
                • Dec 2013
                • 254
                • Netherlands
                Re: asus k42f 3.0
                Forgive my ignorance, but why do a lot of people ask for a bios? After submitting there old bios they receive a new one. Why? What is the symptom of the laptop when you have to change the bios?
                • atsio
                  • Oct 2013
                  • 819
                  • Greece
                  Re: asus k42f 3.0
                  Bios is software and like all software it maybe corrupted. You suspect corrupted bios if you do not find any shorts on board and board does not react to power button although always voltages are present and EC controller as well as Southbridge raise the appropriate signals.
                  Sometimes the board tries to start although the bios is corrupted.
                  The best way to check a bios is by comparing the data signals with one on a working board with an oscilloscope.
                  Usually bios from sites of manufacturers are updates (not complete) and you have to merge the backup from your board with the update provided from the manufacturer.
                  Some manufacturers store in the bios info for the specific board as well as/or Microsoft OEM activation codes that you need to merge in the bios you downloaded from the manufacturers site from your bios backup.
                  That's I think is a short description of why people are asking for bios.
                  • hansie55
                    • Dec 2013
                    • 254
                    • Netherlands
                    Re: asus k42f 3.0
                    Atsio, Thanks a lot for your clear explanation.
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      Re: asus k42f 3.0
                      isn't this funny, cos all bios have write protect pin/bit...?
                      • innocentforeign
                        innocentforeign
                        • Jun 2013
                        • 172
                        • KSA
                        Re: asus k42f 3.0
                        a big thanks for sharing org bios its working
                        Sir, Atsio
                        i really really appreciate your help
                        and also thanks all of you for help
                        • boss juben
                          • Oct 2016
                          • 37
                          • philippines
                          Re: asus k42f 3.0
                          if the other technician gave you new bios then you try but not working try to isolate the motherboard,
                          • Marc97
                            • Jan 2016
                            • 189
                            • Phillipines
                            Re: asus k42f 3.0
                            Originally posted by atsio
                            Try this
                            tested file,,, working also on k42f 2.0 good
                            • SirangKap
                              • Feb 2020
                              • 29
                              • Philippines
                              Re: asus k42f 3.0
                              Try this
                              Thank you sir. Your bin file is working. I've tried on Asus K42F Version 3.2
                              • Nurshad
                                • Oct 2019
                                • 75
                                • bangladesh
                                Re: asus k42f 3.0
                                asus k42f rev 3.3 No Display Problem Help Me
                                All Coil Voltage Ok Already Program Bios
                                • peste
                                  • Dec 2016
                                  • 13072
                                  • ROMANIA
                                  Re: asus k42f 3.0
                                  post the original bios of the laptop..
                                  • Sebastian Codrean
                                    BIOS file for ASUS F542UN laptop
                                    by Sebastian Codrean
                                    Hello to all of you! I need help with a BIOS file.
                                    The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                                    So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                                    02-20-2025, 10:25 AM
                                  • jbonavita
                                    by jbonavita
                                    Some issues
                                    Things I tried
                                    04-29-2025, 09:38 PM
                                  • caglarec2268
                                    Asus X515EA Bios File Please
                                    by caglarec2268
                                    merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                                    Now "please follow the steps below to recover your bios" text remains on the screen
                                    I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                                    laptop model x515ea-bq945w
                                    s/n: R4N0CV02K527148
                                    CN:HWFB
                                    Board model; ASUS X415EA R7.0
                                    bios chip: GD25Q128...
                                    11-27-2024, 03:51 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
                                  • grimacelord
                                    by grimacelord
                                    07-10-2025, 02:52 PM
