HP6735s "invalid serial number", bios needed
Re: HP6735s "invalid serial number", bios needed
hxxp://files.elektroda.net/514680,hp+dmi+toolkit.htmlComment
Here is the nbdmifit -2.10 should fix most
Product Information Not Valid
If posted b4 please removeAttached FilesComment
underneath that sticker is a motherboard code which is i guess 6050A2235601-MB-A03
all dumps i found are 2 mb.... schematics also says 2mb SST_25VF016B...
why not take eeprom from other non working board and put it in... its worth a try.... any 2mb spi eeprom should work
did you see traces of soldering when opened? maybe someone did some work before you... :/Comment
HP Elitebook 8460p, fine for many years but after a power outage it went into "Manufacturing Mode". Got past that but was having the "System Board (00A)" not found errors after that and then Windows wasn't activated anymore. This worked for me:
1- nbdmifit -2.10 above, built out a bootable flash drive with this, using Rufus / Freedos.
2- Renamed \wndmifit\FSMC.bin to SMB.bin and copied to root of flash drive.
3- Shut down. Hold windows key, Up-Arrow key, and the Down-Arrow key then the power button. This put my machine back into Manufacturing Mode (required for next steps)
4- Disable UEFI in BIOS (if used), boot directly to USB flash drive with Freedos, run the Run NBDMIFIT.BAT and followed the prompts - this didn't work earlier until I used STEP 3. When done rebooted and no more Manufacturing Mode anymore. Restore UEFI in BIOS if needed.
5- If seeing a "Restore Mode On" message during boot, I was able to fix that by re-running the HP BIOS update program on my device and then rebooting.Comment
what are the command lines for this toolComment
Thank you guys so much, just repaired my old HP Probook 6360b. I had to use the new NbDmiFit-2.09, it is a little bit different than the previous version. Was able to re-program the S/N, CT, Product # now the computer no longer gives me the "invalid System Board (00A) - Product Configuration". Learned something new and was able to repair my laptop, again thank you guys.Comment
You save my life, your DMI tools Work Great on my CQ41 Compaq Laptop. Thank YouComment
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
07-24-2025, 02:17 PM -
by techlabHi Guys,
Looking for some help with an HP Elite Dragonfly.
The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.- The laptop has no power but does take the correct voltage.
- It shows 5 flashes white/amber, which indicates a BIOS issue.
- I backed up the original BIOS to extract the feature byte etc.
- I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
Just wanted to pick your brains on this — has anyone come across this before or...-
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
- Loading...
