hey guys , need k54LY bios dump
  • highpulse
    i hate HP
    • May 2013
    • 1490
    • portugal
    Re: hey guys , need k54LY bios dump
    ok mate , tomorow morning ill chek it
    thk in advance
    • techman1025
      • Jun 2014
      • 497
      Hi
      Your model schematic ant release see if this helps
      Techman1025
      • highpulse
        i hate HP
        • May 2013
        • 1490
        • portugal
        so my friend here am i to give some relate about this job , so after making some measurement , i cheked having ldo 5 volts on main regulator aqltough i dont have 5 volts on coil , only 0.96 volts , but the 3.3 line is with the correct value , started cheking SPI pins and noticed having high values of 3.04 volts , on pins 1 2 5 and 6 . thinking about SPI could be on the KB(my bad here , i replacedd the kb but with no joy ) after cheking schematic notice that the spi block was on the BD itself , reflowed the BD but still the same , since i have pratically major parts of spares in stock , lifted the hm65 and replace with a new one ... TCHAM RAMM it turned on .....well not for big joy , i turned it off , once i try to turn on , well dead again !!!!
        ready to close this ... guess it killer the pch again !
        opinions ?? well they are more than welcome !!!
        • techman1025
          • Jun 2014
          • 497
          Hi well what's the out come?
          Techman1025
          • highpulse
            i hate HP
            • May 2013
            • 1490
            • portugal
            have you read the post above yours robert ?
            • highpulse
              i hate HP
              • May 2013
              • 1490
              • portugal
              #26
              well we are closing this machine , each time we lift the pch machine will turn on but only once , seems like waterdamage , something weird , is happening and we've lost to much time with this unit allready . thk anyway for does who spent time creating the bios , we will keep it for future reference thats for sure .
              thk guys
              • crocush20
                • Feb 2016
                • 17
                • qweqweq
                #27
                board is a K54LY REV 2.0 search
                • souaqi01
                  • Dec 2015
                  • 87
                  • Maroc
                  #28
                  think
                  • malangg
                    • Sep 2014
                    • 34
                    • United Kingdom
                    #29
                    https://yadi.sk/d/8TBADXOFpUQcR
                    huge dump package for asus bios
                    • islammostafa.me19
                      • Jul 2017
                      • 39
                      • egypt
                      #30
                      thanks
                      • madjionicar
                        • Aug 2014
                        • Deutchland
                        #31
                        Just flashed BIOS from ala_borbe (second post) and it's worked.
                        TNX
                        • Dilane
                          • Sep 2015
                          • 38
                          • Srilanka
                          #32
                          Originally posted by techman1025
                          Hi
                          Here is the new file i made for you .....if this don't work you have other problem ..to know if bios is working rsmrst 3.3V S5 3.3V do you have it caps light up on keyboard if pressed or usb mouse lighting up if yes to all bios is work enjoy.
                          Techman1025
                          thank you ,its working fine
                          • whitevolf
                            • Feb 2014
                            • 124
                            • TÜRKİYE
                            #33
                            thank you
                            • iyori20
                              Banned
                              • Nov 2018
                              • 43
                              • maroc
                              #34
                              tank you
                              • electronica
                                • Apr 2014
                                • 89
                                • algeria
                                #35
                                backup your old and try both
                                thank you . bios working
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
                                • mkdj
                                  by mkdj
                                  Dear all,
                                  10-19-2025, 04:41 AM
                                • Habble7
                                  by Habble7
                                  Suspected Cause:
                                  Troubleshooting Attempts:
                                  05-22-2025, 07:28 AM
                                • haitham sharabati
                                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                  by haitham sharabati
                                  Hello engineers 😀,
                                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                  🔧 Device Info:
                                  - Model: HP 15-da2007ne
                                  - Product Number: 8XF55EA#ABV
                                  - Serial Number: CND0338P0D
                                  - CPU: Intel Celeron N4000
                                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                  💀 Problem:😅
                                  - Device shows “Administrator Password”...
                                  08-07-2025, 04:54 AM
                                • Citymin
                                  by Citymin
                                  S/N : 5RNK9FFT70...
                                  08-05-2025, 05:12 AM
