Toshiba L510 bios dump
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hi guys need help for my toshiba l510. i need bios dump file.. thanks
  • nazrul145
    • Jan 2014
    • 339
    • BD
    Re: Toshiba L510 bios dump
    give full model and motherboard code. Also upload ur old dump.
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      model: Pslf8l-00u001
      board: 6050a2250501-mb-a03 rev 2.10
      • nazrul145
        • Jan 2014
        • 339
        • BD
        Bios from toshiba site.
        • ry x hunter
          • Jun 2013
          • 184
          • philippines
          sir that laptop is automatically power on and the processor is not respond..
          i alreadr replace nec token and flash bios already but still not ok
          • degutji
            • Dec 2012
            • 173
            • Indonesia
            Core I3 or Core 2 Duo ?
            • ry x hunter
              • Jun 2013
              • 184
              • philippines
              core 2 duo sir
              • meritosari
                • Oct 2010
                • 774
                • Indonesia
                core2duo ddr2 rev 1.4
                try this:
                • marsupial.path
                  • Dec 2016
                  • 14
                  • papua new guinea
                  please help, i need bios for ;
                  Toshiba L510 (HM55-I3)
                  board code: 6050A2264201-MB-A02
                  main+ec bios
                  thanks
                  • Bonzas
                    • 474
                    • Indonesia
                    main+ec bios
                    thanks
                    no one have for this board ?
                    i need too. i found many bios from other forum. but they only give 4 mb and no one uploaded 1 mb bios for ec
                      • 22293
                      Bios + EC.
                      • Bonzas
                        • 474
                        • Indonesia
                        Originally posted by SMDFlea
                        Bios + EC.
                        thank sir.
                        lights on + fan spinning now.
                        after replace some short caps near ram laptop working perfectly
                        • andresi
                          • Nov 2020
                          • 160
                          • INDONESIA
                          help sir, my toshiba L510 (PG10ML), No display
                          • haziqaizat
                            • Feb 2023
                            • malaysia
                            do you have bios bin for this model
                            MOdel no : PSLF8L-019001
                            Board No : 6050A2303001-MB-A02
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • Habble7
                              by Habble7
                              Suspected Cause:
                              Troubleshooting Attempts:
                              05-22-2025, 07:28 AM
                            • haitham sharabati
                              [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                              by haitham sharabati
                              Hello engineers 😀,
                              I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                              🔧 Device Info:
                              - Model: HP 15-da2007ne
                              - Product Number: 8XF55EA#ABV
                              - Serial Number: CND0338P0D
                              - CPU: Intel Celeron N4000
                              - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                              💀 Problem:😅
                              - Device shows “Administrator Password”...
                              08-07-2025, 04:54 AM
                            • DProf.
                              TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
                              by DProf.
                              High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
                              Toshiba Dynabook T55/AB, PT55ABP-BJA2
                              MODEL NAME. Satellite L50-D series
                              P[ART NO PS57MN-00600R
                              Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
                              09-26-2024, 04:30 AM
